Hope XC front hub s...
[Closed] Hope XC front hub service - Advice required
I've found plenty of guides on how to service the rear hub, but I can't find any for the front. Anyone got any links?
Alternatively, can anyone advise me on how to get the outer covers of the hub, please?
Posted : 14/07/2009 8:36 am
Just prise the covers off, the same as the rear
Then just knock the axle through
Posted : 14/07/2009 8:39 am
 cp
there are some good instructional videos on the hope website.
it's very simple - prise the caps off with a screwdriver, put the hub on top of a vice with the axle dangling between the plates of the vice. Using a mallet/hammer, tap (**** in some cases) the end of the axle so it pops out the bottom - it will take a bearing with it. turn the wheel over and from the inside, tap out the bearing that's left in the hub.
re-build is the reverse of the above, but make sure you knock the bearings back in on the race which is restrained - i.e. for mounting on an axle, use a small socket to form a drift on the inner race and hit the socket, for pushing the bearing into the hub, use a larger socket on the outer race.
Posted : 14/07/2009 8:42 am
 cp
oh, when hitting, make sure you're supporting the hub, NOT the rim or spokes (you'll prob be resting on the spoke heads)
Posted : 14/07/2009 8:43 am
One tip if you're using a steel hammer
Drop a screw or bolt in the axle & hit that rather than the axle itself
Posted : 14/07/2009 8:45 am
It's the prising of the covers that I'm struggling with. I don't seem to be able to get the leverage that you can against the cassette body on the rear.
Posted : 14/07/2009 8:47 am
Use one screwdriver at right angles under the other
Posted : 14/07/2009 8:48 am
2 screwdrivers = how easy was that!
Thanks, chaps.
Posted : 14/07/2009 8:50 am
Ummm, can't get the samller spacer off now.
Am I just crap?
Posted : 14/07/2009 8:59 am
Knock it out with the axle
Posted : 14/07/2009 9:00 am
Managed to prise it off with a knife. This was so much easier when I lived in Plymouth and got Fatmuthahubbard to do all my fixing.
Posted : 14/07/2009 9:05 am
