Hope Tech 3 V4 Brak...
[Closed] Hope Tech 3 V4 Brakes
[#6776907]
Do these work with 160mm/180mm rotors or must I use 163/183mm rotors. Will the reduction in radius of 1.5mm of rotor make a difference?
Posted : 13/01/2015 4:50 pm
If the rotor is too small, it can form a lip on the pads. When the lips meet, it limits the force the pad can apply to the rotor.
Posted : 13/01/2015 4:57 pm
Does anyone on here use these with 160/180mm rotors?
Posted : 13/01/2015 6:05 pm
I think the V4 specifically need the vented rotor as it is wider then normal to allow for the thicker rotor. Which may mean the pistons have further to travel to a normal disc and over extend.
Be something to check first other wise it is just 203mm rotors.
Posted : 13/01/2015 6:06 pm
Yup V4 takes a 183 or 203 rotor, doesn't need to be vented but its more DH orientated.
Posted : 13/01/2015 6:30 pm
