Hope Singlespeed hu...
[Closed] Hope Singlespeed hub - how tight?
Hope hub in track ends, how tight do you do the 8mm bolts up? As far as i can tell from the Hope exploded diagram for the hub the load will be placed on the end caps and then the axle so by cranking it up tight i am not excessively loading the bearings. So on that basis i can errr on the side of tight to avoid any unwanted movement in the rear wheel. By tight i mean using a normal size allen key, not a three foot monster. Wheel is on a bike that is likely to case jumps with regularity (bikes fault, not the riders) and go through some reasonably rough terrain at a fair pace hence why i am keen to get it tight.
Posted : 31/12/2018 9:45 am
As tight as you can, then a grunt more.
Mine has always moved a little over time however tight I've done it up.
Posted : 31/12/2018 9:48 am
Think a bit more grunt then. Wanted to be sure i wasn't squashing the bearings.
Posted : 31/12/2018 10:39 am
Yeah, all the force is on the bolts and axle.
Posted : 31/12/2018 10:52 am
i put "proper" bolts in mine and carry a 17mm ring spanner, not because of slippage but the original hex bolt were made of cheese and doing the above was not recommended.
Posted : 31/12/2018 11:01 am
I switched to a normal Hope hub with QR and spacers for SS with two Surly cogs for gear choice (not moving obviously). But I ride a bike (Genesis ioid) with rear facing bolts to provide tension in the drop outs. Wheels have never moved. To drop the wheel out I can remove the skewer. By contrast my fixed wheel road bikes all have track nuts cranked up tight and I carry a sawn off spanner.
Posted : 31/12/2018 12:24 pm
