hope pro II
[Closed] hope pro II
[#496385]
what size bearings for the back hub?
anywhere online i can order?
Posted : 23/04/2009 5:13 pm
 JB
I think they are 6002 but check the Hope Website, worth getting SKF bearings they last longer and are about the same price as the Hope supplied version... buy them from here..
www.simplybearings.co.uk/shop/ball_bearings.php?gclid=CIudnZuzh5oCFQNfFQodHhyWEQ
JB
Posted : 23/04/2009 5:18 pm
6802 2rs x2
6903 2rs x2
6902 2rs x1
Posted : 23/04/2009 5:23 pm
6802 2rs x2
6903 2rs x2
6902 2rs x1
DOH!
Posted : 23/04/2009 5:24 pm
sorry dumb question there are 5 bearings? thanks
Posted : 23/04/2009 5:29 pm
Yes in the Hope Pro II rear there's 5.
Posted : 23/04/2009 5:30 pm
£60 - seems a bit excessive! new hub is only twice that!
are some of these freehub bearings that i don't need - i'm a tight arse!
Posted : 23/04/2009 5:33 pm
£60 seems to me you got something wrong some where bearings are about £4 each.
Posted : 23/04/2009 5:35 pm
Try these guys, good replacement cartridge bearings at a reasonable price
can reccomend
http://www.mountainbikecomponents.co.uk/basket.asp
£4 i've got them at £11.95 each. what am i oding wrong! 😳
Posted : 23/04/2009 5:38 pm
Maybe your not it's about 3 years since I ordered any. 😕
Posted : 23/04/2009 5:40 pm
OK 😀
thanks for the help - i'm sure once i get the bearings out it'll all make sense.
Posted : 23/04/2009 5:50 pm
You will probably find that not all the bearings are worn
Posted : 23/04/2009 6:01 pm
You'll find bearings dealers on ebay. I got all 5 bearings dead cheap from webtradersonline0791 (an ebay shop). Bearings from bike shops/sites tend to be a lot dearer in my experience. There are a couple of specific tools (Bearing drift, hub support) made by hope which make replacement a lot easier but I daresay you could bodge something. A set of circlip pliers is also handy. Using the right tool is always "nice" and avoids a lot of gnashing of teeth. Oh, use a rubber/plastic mallet too if you can, helps you really whack in the bearings without damaging your hub.
Posted : 23/04/2009 6:53 pm
Heat the hub with hot water and freeze the new bearings - this will make it much easier
Posted : 23/04/2009 6:56 pm
The 3 freehub bearings only need doing if the freehub has play. If just the hub has play (noticable at the rim) then it's just the 2 6903's you need.
Hope use INI and are avaiable from 18bikes for about £5ish. SKF are overpriced for MTB use IMO and don't last twice as long. The cheap £1.50 Ebay alternatives lasted me about 3 weeks compared to about 6 months with the INI's.
The Hope tools are inexpensive and well worth the money (again 18bikes can supply), I struggled to find sockets deep enough for the Pro2's. Although mine is the 10mm bolt up axle which may be larger in diameter than the QR version. The old XC hubs were easy with sockets.
Posted : 23/04/2009 8:50 pm
Unless I've forgotten something as been ages since I did mine you don't need circlip pliers it's all just push in.
Posted : 24/04/2009 11:43 am
Anthony, where were you when I posted a thread on this last week?? I spent ages "bullying" my bearings out of my XC freehub only to find they were OK - apart from the one I cracked when trying to remove! Should have just done the hub body bearings then, eh? 😥
Posted : 24/04/2009 11:53 am
Personally I replace them all as if one has worn then it's puts pressure on the others increasing their wear, stick some new bearings in with part worn bearings and their all going to have shortened life. Of course I could be wrong but that's how I see it.
Posted : 24/04/2009 12:02 pm
