Hope Pro II Rear Be...
[Closed] Hope Pro II Rear Bearing Relacement
[#1435004]
I've found the bearings. I've seen the video.
Is it really nessasary to buy the 'special tool' or is this something else that can be done with a bit of initative?
Posted : 22/03/2010 9:46 am
do you mean that block of metal they use to drift the bearings in ? I did a front bulb without that tool but for the sake of the £10 or so it costs I would probably buy one next time, saves the risk of damaging the hub or bearing. I'm sure you could knock something up if you have a lathe, but I dont
Posted : 22/03/2010 9:52 am
 br
TBH While it is perfectly feasible to do it with whatever bits 'n pieces you have lying around, just buy the kit - then its very easy.
Posted : 22/03/2010 10:41 am
OK so the tool is a htt174. Any idea where I can buy one?
Posted : 22/03/2010 2:14 pm
18bikes
Posted : 22/03/2010 2:15 pm
Whe you do it heat the hub. tie a rag around it and pour boiling water over it - it makes it much easier
Posted : 22/03/2010 2:19 pm
put lots of grease in the bearings too.
Buy the whole kit from 18bikes @£19.50 and you get all tools to do F & R Pro IIs,also they are the cheapest for SKF bearings for said hubs!
Posted : 22/03/2010 3:25 pm
 DrP
I'm sure the correct tool does it easily enough, but I found that a bench vice, plank of wood with a 22mm (i think) hole drilled in it, and some 16mm sockets worked a treat....
DrP
Posted : 22/03/2010 3:35 pm
Just did mine. With a bit of silicone lube the bearings slipped onto the axle easily enough with a just bit of body weight behind it, and then only a gentle tap to get the bearing to seat in the hub body.
I was surprised at this, since changing the bearing in my old bulbs was rather more difficult - the interference fit must be a little looser on pro2s.
Posted : 22/03/2010 3:44 pm
16mm sockets are chamfered......the correct tools are not so you will risk damaging the new bearings
Posted : 22/03/2010 6:41 pm
I used a seatpost shim that was the right size.
Posted : 22/03/2010 6:50 pm
erm I'd guess it's more about tolerances...
Posted : 22/03/2010 6:51 pm
