Hope pro 3 sp hub -...
[Closed] Hope pro 3 sp hub - play on 15mm axle?
 FAIL
Annoying problem with my front wheel - 15mm axle done up correctly (as far as I can tell), there is still a bit of play i.e wobbly wheel. The bearings are new and proper hope ones, and the only other 15mm front wheel I have doesn't have any play at all when mounted in the fork. Fork is a rockshox SID RLT.
Anyone else had this problem?
The 15mm adaptors feel a bit loose when the wheel is out of the fork, not sure if this is normal
Posted : 07/05/2013 6:32 pm
