Hope Pro 2 Hubs - w...
[Closed] Hope Pro 2 Hubs - what holds the 20mm adapters in?
as it says - just go one and they just seem to fall out. Looked on the Hope web-site and it doesn't seem to show any circlips or anything.......... or do they just sit in loose?
thanks multo
Posted : 08/01/2009 10:43 pm
no, they use circlips
Posted : 08/01/2009 10:44 pm
The spacers?
On my bulbs theres a circlip on each side
Posted : 08/01/2009 10:45 pm
Their held in with a fine stainless type of circlip (a bit like a thin piston ring), plain with no hole for pliers. Best to use a small blade or jewellers screwdriver to gently prize one end out, then folow it round till its out.
Posted : 08/01/2009 10:49 pm
thanks - though so. Are there any o rings or anything between the spacer (better word than adapter) and the bearing - doesn't seem that well sealed.
cheers again
Posted : 08/01/2009 11:05 pm
Bulbs and pro II both use clips to hold the spacers
Posted : 08/01/2009 11:22 pm
