Hope Pro 2 and Evo ...
[Closed] Hope Pro 2 and Evo replacement bearings?
Do Pro 2 and Pro 2 Evo hubs use the same Hope bearings?
I'm looking to take some spares on a 6 week trip this summer, one bike is Pro 2 and the other Pro 2 Evo.
How easy is it to change front and both sets on the rear without the proper tool (assuming it is possible to do with the usual hammer + socket set kit...)
cheers
Posted : 17/04/2012 9:19 am
 br
[i]How easy is it to change front and both sets on the rear without the proper tool (assuming it is possible to do with the usual hammer + socket set kit...)[/i]
Its easy, but also easy to f*** it up... Just buy the tools from Hope, they make it child's play.
Posted : 17/04/2012 9:21 am
Front (3 minutes with a big hammer):
Rear: (slightly longer and using proper tools):
[edit] for a 6 week trip I'd fit new bearing in advance and risk it. Or swap to Shimano hubs...
Posted : 17/04/2012 9:23 am
Thanks.
Not had issues with Hope bearings, and was thinking about replacing a GPX BB with a Hope one today.
Any answer to the question about whether the 2 types of Hubs use the same bearings?
Posted : 17/04/2012 9:55 am
Check on the hope site? they usually tell you the bearingnumbers
bearing numbers on the PDFs above
Posted : 17/04/2012 10:25 am
fronts are the same, rears are slightly different to allow a stronger axle for 10mm thru.
Posted : 17/04/2012 11:31 am
