very confused what do I need? I'm putting a 1 1/8th fork into a 2011 transition covert, preferably with a low stack height - was planning on using a reducer crown race.
as far as I can tell, I need a '2' top cup, but I'm confused about the bottom cup. I found one place that said the lower shell was 49.6mm. Does that mean I need a 'D' cup ๐ and I can't use the reducer crown race?
๐
Dave
Posted : 15/11/2011 11:31 am
aha, it appears that there is also an 'F' option, which isn't on that picture - the F is a traditional (external bearing) 1.5" cup with 49.56mm diameter into which I should be able to use a reducer crown race.
Dave
Posted : 15/11/2011 11:58 am
