Hope pedals
[Closed] Hope pedals
[#8294900]
I am in the market for new flat pedals after having loads of problems with play in my VP Harrier,are Hopes worth the money
Posted : 19/01/2017 10:47 am
I'm as fond of bling as the next man*, but couldn't bring myself to believe they'd be twice as good as other pedals that were around half the price**... 😕
EDIT *and, in fact, probably fonder than many...
EDIT **or three time as good as pedals around a third of the price
Posted : 19/01/2017 10:55 am
Weird, just came here to ask about new flats for my new bike.
Posted : 19/01/2017 10:56 am
They're very nice pedals - good shape, good grip, well made (of course) and as with almost anything from Hope will last a lifetime with maintenance (which can be done, as they'll have any spares you might need, unlike some).
They're also pretty expensive and there are lots of good, modern, flat pedals on the market. You can get something 80% as good for 50% of the price (sometimes less) so it's a question of whether that extra 20% is worth the significant additional cost, to you.
Same as with their hubs, headsets, BBs, etc.
IMHO, yes, they're worth it - but then we sell them!
Depends what you mean by worth the money. I like mine better than the Nanos I also have, but I didn't pay anywhere near full price for them either. If you're looking for vfm then Nanos are the choice, but I suspect the Hopes will last a lot longer.
 wl
After 9 months of hard use on a hardtail I can't fault my plastic Nukeproofs - they weigh nothing, grip like glue and were £29.
Posted : 19/01/2017 11:00 am
wl - Member
This.
The nylon Sam Hill versions have been brilliant through summer and winter, the bearings are still perfect, they deliberately don't spin freely so foot placement after a dab is a breeze, I expected this "stiction" to be the first feature to wear out but it's still perfect.
The replaceable steel pins are all fine and correct, but two of the molded pins on the outer edge have worn off due to pedal strikes riding rocky climbs..
So highly recommended
Posted : 19/01/2017 11:13 am
 Leku
I have a pair of Hope pedals.
I started with plastic Nukeproof ones but I found that when a pin gets bent, the softer plastic body stops you replacing them.
Then Superstar Mags. Failed under warranty.
Replaced with UK made Superstar ones. Failed again but couldnt be bothered to go through (painful) warranty.
It was my birthday so got the Hope ones. Slightly wider platform than the above. Maybe not quite as gripy. I'm very happy with them.
Posted : 19/01/2017 11:16 am
Both my favourite bikes have Hope flats, because they are worth it.
I really like them and have had no problems. On my MTB I originally had Spank Spike pedals that also cost a lot but seized within 1 year.
Posted : 19/01/2017 11:35 am
got some. good but not great.
pins are nice as that dont cut your shins but you need 5:10 to not fall off them.
running nanos after rebuilding the hopes (30quid in bearings!!!!) they are better imo but have gone wobbily after only a few months usage. Hopes took some right hammer for 3 years before needing any attention.
Posted : 19/01/2017 11:51 am
 edd
I've run a pair of Hope flats since 2013. They're dead reliable and spares availability is great (in fact they were rebuilt - their first ever maintenance - this winter).
I don't find them as grippy as other pedals and they're really expensive. Personally, if they were to need replacing I'd get something cheaper and grippier (I loved the Nukeproof Electron's that I had before). That said if you value reliability they're great.
EDIT:
That's what it cost me too. I almost bought some new Nukeproof's instead!
Posted : 19/01/2017 11:54 am
Main MTB has either Hope pedals or SPDs depending on what I'm doing. Fat bike has the plastic DMR pedals (V5?) as I'll be using it in Lapland in rather cold weather so an attempt not to have a cold sink attached to my boots!
Posted : 19/01/2017 11:58 am
andybrad - Member
This. They are made slightly better by removing the pins from the middle of the pedal but they are still decidedly average. SS Nanos are better
Posted : 19/01/2017 12:02 pm
I have a couple of pairs and really like them. They offer the perfect amount of grip for me in any shoes / trainers. I have had other pedals that are far too grippy and don't allow any foot movement which I find is more of a problem than too little grip.
One pair of mine are nearly 3 years old and the other pair is nearly 2 years old and both still run as smooth as the day I bought them despite being used in any weather.
Posted : 19/01/2017 12:04 pm
Do the Hopes do anything that Saints don't?
Posted : 19/01/2017 12:30 pm
I'm intrigued by the new Canfields.
http://www.cranknuts.com/canfield-brothers-new-crampon-mountain-pedals/
Posted : 19/01/2017 12:34 pm
fourbanger - Member
They aren't great but they're still better than Saints in every way
fourbanger - Member
Like not grind their bushes and bearings to dust and offer a platform larger than a kid's size 10? Yeah, they do that. In fact, I think pretty much every pedal apart from Saint does those things too.
Not sure what Saints weight now but they were bulky and heavy. I like a low profile pedal and have had the superstar mag somethings with a ti axle for 2-3 years but bent the axle the other month and got some hopes second hand for £50. They are decent, big platform and look well made / bearings are smooth after what looks like a fair amount of abuse (most of the anodising has come off).
I really really liked my superstars, they were slightly nicer than the nanos and weighed bugger all.. gutted I couldn't find a spare axle to be honest..
The hopes are good but imo not worth £130.. they are only worth that if you smack pedals all the time and want a big box of easy to find spares.
I don't find them "less grippy" they feel pretty planted with five tens and like has been said if the middle pins are removed your foot sits in them more.. they could probably do with being a little concave.
They'll work out cheaper than my superstars did in the long run as I can get spare axles ect..
Posted : 19/01/2017 12:37 pm
but then if you run normal Superstars a spare axle is a fiver (or something silly cheap like that)
Posted : 19/01/2017 12:40 pm
Managed to get the Hopes for £89.99 from Wiggle
Posted : 19/01/2017 1:53 pm
What's wrong with Saints? I have an old pair and seem indestructible, if a bit bulky as mentioned.
Over 600 5* reviews on CRC.
Do they have a problem with bearings?
Posted : 19/01/2017 3:41 pm
They were normal superstars until they stopped making them...
Posted : 19/01/2017 5:13 pm
If you have to ask then, no, they are not for you. You buy Hope pedals because you want to buy Hope pedals. At least that's why I bought mine 🙂
Posted : 19/01/2017 5:25 pm
fourbanger - Member
Saints are pretty crap, superstar and/or the various copies are much better for that budget
Hopes are very well made, but not massivey grippy or well shaped.
Posted : 19/01/2017 5:40 pm
Are they better than DMR Vaults?
Posted : 19/01/2017 5:42 pm
I really like the Hopes. I've been through quite a lot of flat pedals in the past few years. Off the top of my head: Nukeproof Proton, Superstar Nano, Nukeproof Neutron, Superstar Delta, DMR Vaults, Crank Bros Stamps, DMR V8s, Wellgo something or others, some terrifying spikey Straitline things, and various others on hire/demo bikes that didn't inspire any strong feelings. The Hopes are definitely the best I've used (and they weren't the most expensive either). Very grippy, very comfortable, a rock solid design and incredibly well put together.
But pedals are a very personal thing - what's better for one person doesn't mean it's definitely better for another. For example I find that I only really get on with pedals that have pins towards the centre of the platform, the more normal design with pins round the edge just don't seem to work for my feet for some reason. The F20s are the best pins-in-the-middle pedals I've encountered so far, but if you get on fine with normal Nanos or Vaults or something like that, then there's no need to get all fancy and splash out on the Hopes.
Posted : 19/01/2017 7:00 pm
