Hope mono mini (bla...
[Closed] Hope mono mini (black & gold version), what's the maximum rotor size?
I have a no. 3 caliper, what's the largest rotor it can take on the front wheel?
cheers ๐Ÿ™‚
Posted : 29/01/2009 5:50 pm
Mine is running a 180 disc is that helps!
Posted : 29/01/2009 5:54 pm
hmmm... i thought a 180mm disc would be OK, but when I set it up and clamp the QR, the disc sits too far into the caliper and the wheel won't turn?
Posted : 29/01/2009 6:00 pm
220mm with a +40mm adapter
Posted : 29/01/2009 6:19 pm
Would it be with a Shimano hub, and a RS fork perchance?
Posted : 29/01/2009 7:11 pm
No.3 caliper is definitely for a 180mm front disc, are you sure yours isn't a 183mm?, sometimes you can just get away with it, sometimes not.
Posted : 29/01/2009 7:56 pm
