Is this
http://www.chainreactioncycles.com/Models.aspx?ModelID=2509
The right service kit for this lever?
yes
Yes, have you seen this link for a 'how to'
http://steveukmtb.wordpress.com/220/
Please update with how it goes - I've got a leaking Mini lever and a service kit waiting to become one when I get chance.
Cheers for the guide - I was just going to wing it! Just need to order some circlip pliers from ebay and then ill post an update once I have done it
you can get te whole thing servced from Hope for £40 including bleed fluid change new pistons and new pads...they replaced my mates hose as wel wen they did this. Parts alone are not much less.
Well I got the parts and disassembled the lever which took about 5 mins to do! Then found that the spring had disintegrated into this...
I was doing this for a friend and the bike has been ridden for about 6 months. I think the seals have gone and water has got into the lever as there was a lot of rust around the seal and circlip
Get yourself to a Hope tech shop, they usually have boxes of just about every spare part they might need.
Give hope a call or email them they are really helpful and will probably send them to you FOC.
