I'm trying to convert my Hope Pro 2 Evo Straight Pull Hub so i can use on my new frame, i bought some spacers online (Hope Pro 2 Evo MTB Rear Wheel Axle Conversion Kit Black Silver Thru Kit) The problem is there not wide enough for the frame Niner SIR 9 which is 142 X 12. they also had another kit x12 not sure what that is, also i'm assuming the silver spacer will be on the Cassette side. so if anyone is familier with the correct
spacers or a link were there for sale that would be good.
Posted : 07/02/2016 5:35 pm
Sounds like youve bought a 135mm x 12mm kit, The one you need is the X12 kit. (X12 is the name which was originally given to 142mm x 12mm)
Posted : 07/02/2016 5:44 pm
Thanks dhrider.
Posted : 07/02/2016 5:50 pm
