Hope Hoops Pro3 SP-...
[Closed] Hope Hoops Pro3 SP-XC built on Stans 355 rims - any good for trail centres??
Thinking of buying the above wheelset but was wondering if they would be good for trail centres/peaks riding or whether they aren't burly enough? I won't be doing any jumps but will be doing step downs and rocky trails.
Posted : 18/09/2009 1:05 pm
Should be fine, unless your particuarly heavy on parts. Seen people ride some technical/rocky descents with them.
Posted : 18/09/2009 2:22 pm
How many spokes? They sell pro3 SP_XC with different amount of spokes. Mine were 24 spoke or was it 26?
Posted : 18/09/2009 2:23 pm
Won't be 26, could be 24.
They'll be fine! 355s aren't exactly fragile unless you're particularly fat and a bad rider!
Posted : 18/09/2009 2:24 pm
Had a set from wheelpro (24 spokes) stood up to loads of abuse - peaks, afan, brechfa, gethin mountain ash and 2 24 hour races
Posted : 18/09/2009 2:26 pm
Cheers peeps. Will put an order in then ๐Ÿ™‚
Posted : 18/09/2009 2:36 pm
 Davy
Will they be fine for manicured man made trails? I'd have thought so... ๐Ÿ˜†
Posted : 18/09/2009 4:08 pm
Posted : 18/09/2009 4:37 pm
at the when i bought my hope pro 3 /355 from roger m he commented about the above pic
Re: STW forum broken hub. This won't happen! I have my theory about why you sometimes see broken Hope hubs. Don't quote me on this but I think bad building is a contributing factor, some of the handbuilts I see have some scary spoke tensions - some spokes slack and some way tight and this imbalance adds stress to the hub flange. Every wheel I build has uniformly tensioned spokes and this includes the Hope Hoops which I check and adjust (even a ยฃ200,000 machine is not perfect at spoke tension).
Posted : 18/09/2009 4:49 pm
