I am running 9 speed set up with these but would like to put them on my other bike which is 10 speed, will they fit or will i have change anything...
Short answer yes
Long answer yes, because the 10 speed cassette is designed to be the same width as a 9 speed.
Cool! Thank's ๐
IIRC 10sp road cassettes are marginally narrower than 9sp, so you need a thin spacer at the wheel end of the freehub. Are MTB 10sp cassettes the same?
Andy
If a spacer is required to fit the cassette it should come with it.
IIRC, no, partly because I guess they're designed with compatibility with existing wheels in mind, but I'm not 100% certain.
Will have a go fitting tomorrow..
No spacers with 10 speed MTB cassettes, it'll go straight on.
That go for SRAM as well, given that SRAM MTB & road groups are purported to be cross compatible?
Andy
Yep.
They fitted no bother,
Thanks for the info ๐
