Are the evo caps different from the older tip? Thanks
Posted : 20/08/2012 9:20 pm
Front end caps / conversion kits are the same as the older Pro 2.
The rear conversion kits are different due to the axle being different. Not 100% sure if the actual caps are different.
Posted : 20/08/2012 10:02 pm
Front same
Rear different, the evo axle is made of 2mm thicker tube so the evo caps just fall out of you try to put them on an old hub
Trust me after taking (wrong) advice from hope I tried it and had to send the evo caps back (hope where good aBout it And sent out free replacements)
Posted : 20/08/2012 10:44 pm
