Just wondering if anyone has used Stans tubeless tape on Hope's Enduro rims (26"), which kit did you go for???
Thanks
Tim
25mm on the tech Enduro.. (It's 21mm for tech xc).
^^^this
I used superstar tape (worked a treat BTW) but I rang Hope first and they said 'ey up lad, we use t'wenty farve' so I got that.
25mm it is, many thanks people.
Sorry, one more question - for 25mm is the best suited kit the Stans Enduro kit ( http://www.chainreactioncycles.com/stans-no-tubes-enduro-tubeless-kit-2014/rp-prod116723), it's listed as 25-28mm.
Is that the £50 odd kit? (Link not working for me)
You only need tape and valves, not the rubber rim strips. Which will come to £10-20 or so.
timchampion - Member
Try this very much cheaper kit (you probably want more fluid, mind)
http://www.chainreactioncycles.com/ie/en/hope-tubeless-kit-for-hoops-on-stans-ztr/rp-prod49111
Thanks George, I saw this kit but wasn't sure if it was compatible with Hope's own brand rims.....
