Hi,
I’m about to fit some Hope E4s to my 2017 Specialized Enduro and not sure what adaptors I’ll need to do the switch. It’s 1X11 with a command post.
Any advice is greatly appreciated.
Thanks.
you'll more than likely need the hope caliper adaptors (post/is and post to post assuming floaters are different sized to standard fork/frame size), regular shimano ones can be a problem.
- Mount A-Post Caliper to IS (F-160/R-140)
- Mount B-Post Caliper to IS (F-203/R-183)
- Mount C-Post Calipe to Post (F-203/R-203)
- Mount D-Post Caliper to Boxxer, pre-2010 (F-203)
- Mount E-Post Caliper to Fox 40 (F-203)
- Mount F-Post Caliper to IS (F-180/R-160)
- Mount G-Post Caliper IS (R-203)
- Mount H-Post Caliper to Post (F-183)
- Mount J-Post Caliper to IS (F-183)
- Mount K-Post Caliper to Post (R -PM 140-PM 160)
depending on your shifter; sram or shimano and whether you can fasten it direct to the brake levers or they fasten direct to the bars you'll need
HBSP327 shimano XT/XTR http://www.chainreactioncycles.com/hope-tech-3-shifter-mount/rp-prod113073
HBSP325 SRAM http://www.chainreactioncycles.com/hope-tech-3-shifter-mount/rp-prod113073
Thanks that’s a great help. Can I use the same shifter adapter for the command post lever?
not sure about the spec dropper lever sorry.
ps. dont order the caliper adaptors on tredz, i ordered 2 weeks ago and delivery expected 2 weeks, it seems alot of hope gear is out of stock on many sites.
Thanks will have a look around and avoid Tredz!
