Having a bit of an issue setting my rear brake up not to rub. Pistons can be fully retracted and are lubed etc. No matter how much aligning I do, I cant't seem to sort them. It's much worse with 2/3 to 3/4 pads, I can get them going much better with new pads.
So I took my cheap Aldi digital calipers to the rotor and it's down to 1.2mm ish thick, Hope recommend that minimum thickness is 1.5mm for a 183mm rotor. The rotor is nearly 8k kilometres (5 on the front, 3 on the rear) old ridden through all conditions in the Peak, Lakes, Cannock etc. so it's had a pretty hard life!
So could the very worn rotor, along with worn pads be causing my issue?
Surely you’ve just answered your own question?
mashr - Member
Well yeah, I suppose!
Im guessing the thin disc and thin pads combine to allow the piston too far out of its bore where it can rock and get stuck?
breninbeener - Member
That's sort of what I'm thinking, hopefully a new rotor sorts it. It could just be that I'm useless at setting them up!
