Hope bulb hub Q/R c...
[Closed] Hope bulb hub Q/R conversion
[#2850161]
Just bought a pair of wheels from someone on ebay. How on earth do I convert my hope bulb hub so that I can use it on my bike with quick release? My question relates to the front wheel which at the moment has a hole about 22mm in diameter through the middle!
Posted : 14/06/2011 3:03 pm
You need one of these ->
Posted : 14/06/2011 3:05 pm
 nbt
I've got one in the garage. Yours for a tenner
The 20mm hub bits are held in with a circlip - remove circlip, remove end bits, insert the QR convertor (5mm allen key in each to unscrew it / screw it back together)
Posted : 14/06/2011 3:07 pm
Thanks for that, just spotted one of those on ebay but still 8 days to go!! And I want one asap so if anyone has one for sale please get in touch, thanks
err see above (though I see you both posted @ the same time)
Posted : 14/06/2011 3:15 pm
 nbt
Porcaro, I've mailed you
Posted : 14/06/2011 3:22 pm
I'd be very interested in buying your 20mm bulb adaptors once you make the switch to QR.
J
Posted : 14/06/2011 3:27 pm
Just a word of warning. The adapotors for BULB front hubs vary depending on whether it's a 5 bolt ot 6 bolt hub.
Posted : 14/06/2011 3:37 pm
My hub is a 6 bolt hub and 20mm in diameter (not 22mm as I stated above)so please ensure if you offer me for sale it is fit for its purpose, thanks
Posted : 14/06/2011 6:00 pm
Purchased one from 'nbt' above so no longer required, thanks
Posted : 14/06/2011 6:39 pm
If someone still has these (to QR) parts I would be very interested. please offer to mmmmmDOTsaarelaATgmailDOTcom. Thank you.
Posted : 29/06/2011 12:19 pm
I also need one,anyone??
Posted : 17/07/2011 5:30 am
