Not sure what to do as my brakes appear to be working fine but the brake fluid is rather cloudy and dark in the master cylinder, Hope say it's the dye from the seals leaching into the fluid and recommend replacing the seals every 3 years.
Has anyone had their brakes serviced?.... If so were your brakes faulty or just ready for a spruce up and some maintenance? Or did you bleed with new fluid and just go and ride your bike ๐
Posted : 07/06/2013 3:15 pm
If it's not leaking, just bleed it. If that doesn't give the imporovements you want, strip and clean. You'll be amazed what a good bleed can do.
Posted : 07/06/2013 3:17 pm
I used to service mine every few months!! Piss once you've done it & the bits are dirt cheap
Posted : 07/06/2013 3:48 pm
