hope brake mounts
[Closed] hope brake mounts
4 Users
I want to fit a 160 front rotor but which standard post mount can I use, cant find one for this size on the hope site?
Posted : 10/04/2013 7:58 am
What caliper?
Posted : 10/04/2013 8:10 am
Do you need an adaptor for 160mm rotor?
Posted : 10/04/2013 8:13 am
Do you need an adaptor? If your brake and fork are post mount then for a 160 mm disc you just bolt the caliper direct to he fork lugs.
Not with an IS caliper...
Posted : 10/04/2013 8:15 am
ah, thanks. yes caliper is hope x2 evo post mount!!! 🙂
OK bolt it straight on then! Or is your fork IS?
Posted : 10/04/2013 8:16 am
Thanks for the help 😀
Posted : 10/04/2013 9:16 am
