Hi all.
I've got a cotic BFe & hope brakes with 180/160 rotors.
I had it all set up but the rotors sit right at the back of the calipers so there is not enough clearance.
Has anyone else had this problem or know how to sort it out ? Or know where the best place to buy the right mounts ?
Thanks
are they liquid ones?
Yes hydraulic .I just need to know what mounts I need as mine don't fit but they were fine on my soul
Hope M4's fit fine on mine (older model), as far as I am aware no modifications required (shop fitted them - Nirvana in Westcott).
What brake adapter are you using? Pictures?
I can't get pictures on here from my phone sorry.
They are hope monos & they went on fine on the soul but being a pain in the botty with the BFe.
The mounts I found hanging around the garage so I don't know what they are sorry.
I guess I will have to take it into reading
If they are hope mounts they usually have a letter on them somewhere
"are they liquid ones?" hexhamstu, youre on the ball. either that or youve been on here too much today haha.
๐ณexhamstu - Member
OP you've put the mounts the correct way round? Right?
Yes I believe so but I will double check when I get home
Also a bit more info would help.
Did you just do a frame swap from the soul?
What exctly has changed from the working setup?
What model brakes ? PM or IS calipers ?
Actually, I think spectabilis has it. I had similar issues a few years ago. Off the top of my head I think I needed a 20mm adapter for both front and rear brakes. It nearly fitted when when they were the wrong way around, just needed that extra few mm.
As mentioned above - if it worked on the Soul it should be fine on the Bfe. Your mounts are upside down/ wrong way round.
No there the right way round,I spoke to cotic & they said it's odd. Oh well I'm sure it will get sorted at some point
Us it both front and rear? Is it possible that your front rotor is 183 mm and you're using 180 mm mounts?
you haven't used Shimano mounts by accident?
To be honest I don't even remember where I found the mounts but they worked on my soul & even the guys at cotic said that it's weird that they are not fitting on my BFe as they have the same geometry.Its my 1st build & I'm probably just being a pleb but I will double check the sizes.
Thanks for the help
