Hope brake fanbois,...
Hope brake fanbois, you won’t want these
How is “locking up” the measure of any brake for flip’s sake??
I'm kindof with you on this. I'm going to caveat the following with "I am not a physicist" however I see it like this:
When you apply the brakes what you're trying to do is turn the kinetic energy of your bike moving forwards into heat ...and in the case of Hope's, lots of noise :-D.
When you lock a wheel all you're doing is prove that you can very quickly turn the kinetic energy of a wheel's rotation (but not the bike's kinetic energy) into heat. It does naff all to disperse the kinetic energy of the bike (and more specificaly my mass perched upon it) as it hurtles towards a tree. In fact all that happens is that the kinetic energy of the bike is transfered into heat build up of the now-locked tyre scrubbing along the ground.
Now, are there any physicists in the room to tell me exactly how flawed my logic is?
Posted : 20/09/2021 7:12 pm
Something about a plane on a conveyor belt?
Posted : 20/09/2021 7:37 pm
When you lock a wheel all you’re doing is prove that you can very quickly turn the kinetic energy of a wheel’s rotation (but not the bike’s kinetic energy) into heat. It does naff all to disperse the kinetic energy of the bike
Yup, understood 🙂
It's happened when ive come round a corner or bend and suddenly happened upon someone and their dog. A frightened sudden yank on the back.
At least it straightens me up.
Posted : 20/09/2021 8:13 pm
I've got Magura, Shimano and Sram brakes on my bikes, no real issues with any of them.
Might buy some hope calibers for the cross bike though. They're very pretty. 😏
Posted : 20/09/2021 8:14 pm
My road bike has shimano levers and hope calipers...
Posted : 20/09/2021 8:19 pm
I noticed these new levers at ardrock, saw the guy who won the vets, lightning fast down stage 7, so had a sneaky look at his bike back in the event village front of the hope tent, difficult to tell without all the e4s on other bikes
Posted : 20/09/2021 8:40 pm
You can put the bigger RX4 mineral oil piston seals in E4 calipers and mate then to Shimano master cylinders in theory.
That way you get a pretty caliper that won't leak and a more grabby lever that will lead and randomly pull to the bars.
Posted : 20/09/2021 9:02 pm
That is an interesting idea.  If my Magura callipers ever let me down I may investigate further.
a more grabby lever that will lead (leak?) and randomly pull to the bars.
Not experienced that so far but I do agree with whoever said the Shimano master cyclinder could do with a greater capacity.
Posted : 20/09/2021 11:54 pm
Your maximum braking power is achieved with the wheel right on the limit of locking up. If a brake is capable of locking up a wheel, then the limiting factor is tyre grip, not the brakes (this is irrelevant if going OTB is the limiting factor). When you get a brake that can't even lock up a rear wheel, then you know there's something seriously wrong. It's not that you want to lock up wheels, it's that being able to lock them up is a very simple test of whether the brakes are working properly.
Posted : 21/09/2021 2:18 am
Good brakes can apply more braking force before locking up.
Bad brakes lock up with lower braking force applied.
Really bad brakes don't lock up at all.
Therefore ability to lock a wheel is nowhere near a reliable indicator of braking power.
Posted : 21/09/2021 8:57 am
simply impossible - basic physics.
Posted : 21/09/2021 9:12 am
Why not just use rx4 calipers.
@ofked needs to go back to school!
Posted : 21/09/2021 9:20 am
How did GCSE/O'Level physics go for you ofked? 😁
Posted : 21/09/2021 9:25 am
simply impossible – basic physics
Might be worth letting the F1 engineers know. They can save a fortune on carbon ceramic disks as some brakes from a Fiesta would lock the wheels up.
Posted : 21/09/2021 9:33 am
How did GCSE/O’Level physics go for you ofked?
I presume he is getting at the fact that good brakes allow you to feel where the locking up point is more accurately and hence allow you to get closer to the limit without locking up -ie modulation/sensitivity, which is what all the hope fan boys rave about, rather than saying that they increase the grip of the tyre - which is plainly wrong. it was Badly worded , but I think (guess) that was his point.
It's not just feel. It's how quickly you get there, how long and how sustainably you can hold it there, how repeatable it is, and many other factors. There's a world of difference between good brakes and great brakes. Both can lock the wheels.
Posted : 21/09/2021 9:39 am
Because:
E4 have 2 large pistons compared to the RX4
E4 are a different caliper to E4 in terms of bleed port design (E4 needs no special tools)
MTB'ers with Hope brakes are more likely to have a complete set of E4's already and not RX4 calipers
I didn't say I was going to do this - I can set my E4's up properly and have no issues with them on my bikes with them - just it was in theory possible for those who prefer no modulation combined with a lucky dip on whether the lever will hit the bard before the rakes come on, but not having to replace calipers al the time (while claiming it's a bargain because they get free pads).
Posted : 21/09/2021 9:44 am
No, they do not. How much braking force is required to lock the wheel is just a matter of tyre grip. Good brakes have better modulation. That makes it easier to judge how close they are to locking up but it doesn't affect the actual braking effort required to lock up.
A Fiesta brake would not survive on an F1 car. F1 cars use carbon brakes and they glow red hot, that's how much heat they have to dissipate. If you put Fiesta brakes on an F1 car, they wouldn't last a single hard stop - the fluid would boil and the pads would glaze because they could not dissipate heat fast enough. An F1 car's brakes are designed to dissipate probably 10 to 20 times the energy of a small road car's brakes.
Posted : 21/09/2021 9:57 am
A Fiesta brake would not survive on an F1 car. F1 cars use carbon brakes and they glow red hot, that’s how much heat they have to dissipate. If you put Fiesta brakes on an F1 car, they wouldn’t last a single hard stop – the fluid would boil and the pads would glaze because they could not dissipate heat fast enough. An F1 car’s brakes are designed to dissipate probably 10 to 20 times the energy of a small road car’s brakes.
I totally agree that they wouldn't be as good, but they would be capable of locking the wheels. The point is simply being able to lock the wheels is not a good metric.
No, they do not. How much braking force is required to lock the wheel is just a matter of tyre grip. Good brakes have better modulation. That makes it easier to judge how close they are to locking up but it doesn’t affect the actual braking effort required to lock up.
You are missing the time factor. If it takes 1 second to get to locking up then that is less braking force than taking half a second. If you are cadence braking then that makes a difference and you will get more braking force from the better brake
Posted : 21/09/2021 10:01 am
When I ride on ice I can lock up either wheel even if I spray WD40 on the discs. Can we please stop talking about being able to lock up the wheels being any kind of measure of how good a brake is?
Also, on the subject of modulation, I think there can be some confusion between lever travel and force applied. I've tried Magura brakes and hated them. It's the opposite of what I'm looking for in a brake. What people describe as 'grabby' I just think is the sign of a good brake (the exception being if the piston is sticking and then suddenly pops out when you apply enough force).
I want a lever that I can set up close to the bar. I want the bite point to be as close to the bar as possible and then, once the lever is at the bite point, I want as little movement as possible. Braking force should be controlled by the pressure I'm applying to the lever, not the lever movement.
With the exception of Maguras I can normally get my brakes to work this way with some careful set up.
Posted : 21/09/2021 10:13 am
I've got 3 sets of Hope brakes in a box in the garage. 1 set of Mono Mini's and 2 sets of Mono M4s. 2 of them are so old they have IS mounts.
From memory I think it was sticky pistons that relegated all the 4 pot brakes to the spares box and they have stayed there ever since
I'm quite tempted to try and overhaul them but flogging the calipers on Ebay is probably a lot easier. My worry is spending time and effort on them to find out I prefer a £40 set of Deore
Posted : 21/09/2021 10:42 am
Nope, you are misunderstanding the physics.
Lockup occurs when braking force exceeds tyre grip. With non-ABS hydraulic brakes, if you stomp on the brake pedal or lever as hard as you can, you will apply enough braking force to lock the tyre effectively instantly (yes, I'm sure engineers could measure the fractions of a second that it takes for the tyre to deform and lose grip, but as far as human perception goes, it's instantaneous). The lag between applying pressure to the pedal/lever and braking force being applied to the wheel is too small for humans to perceive unless the driver applies the brakes so timidly that it takes time to move the pedal through the freeplay before the brakes start to apply.
The point about having brakes powerful enough to lock up a wheel isn't that this guarantees they are good brakes, it's that, if they can't lock up a wheel, they aren't powerful enough. It's a necessary but not sufficient criterion for good brakes. A Fiesta brakes would not lock up the tyres on an F1 car at full speed, those things have more grip from the tyres than you would believe.
Posted : 21/09/2021 11:00 am
Sorry, but my Fiesta ST brakes are much better than your Shimano Deores.
Posted : 21/09/2021 11:04 am
 igm
But are they post mount or IS?
Posted : 21/09/2021 11:30 am
If an F1 car found itself on a surface that had sufficiently low friction the Fiesta brakes would lock up the wheels just fine.
The point about having brakes powerful enough to lock up a wheel isn’t that this guarantees they are good brakes, it’s that, if they can’t lock up a wheel, they aren’t powerful enough.
I've had plenty brakes over the years that couldn't lock up the front wheel. They were fine. Or maybe they could actually make it lock up. It's not something I ever felt the need to check exhaustively.
The point of the above replies wasn't really to go further down this rabbit hole, it's more to say that being able to lock up a wheel has absolutely nothing to do with how good a brake is.
Posted : 21/09/2021 12:09 pm
 igm
But if you can’t lock the rear how do you do mad skidz?
Cuz tha’s wot biking iz. Mad skidz
Posted : 21/09/2021 12:22 pm
It's a crude indication that they have enough power to use all the available grip. It's not the only consideration, but it's not irrelevant in the way you seem to think. As described above, you aren't going to lock up a front wheel on a mountain bike with a grippy soft tyre on a dry road anyway, trying to do that will end up with an OTB adventure.
Posted : 21/09/2021 12:33 pm
If an F1 car found itself on a sufficiently sick flow trail could it schralp a berm and blow up the Gram?
Posted : 21/09/2021 12:35 pm
Personally I carry a Hope stick with me (it's purple). When ever I want to do a mad skidz I take my Hope stick out and jam it into the spokes of my Hope wheel (it's also purple). The wheel locks up every time so my Hope stick is definitely the best brake I've got.
My Shimano stick is plain black. Not only that, it randomly changes length which means I'm not as confident when jamming my Shimano stick into my Shimano wheels (they're also black). Sometimes my Shimano stick gets oily and slippy which can be quite dangerous when you're trying to do a mad skidz in an emergency.
It’s a crude indication that they have enough power to use all the available grip.
Is this a thing people do to test their brakes? I mean, do people get a new set of brakes and then go out and check they can lock up the front wheel?
Posted : 21/09/2021 12:39 pm
Not an extreme fanboy but I started using Hope 20+ years ago when their 4 pot DH brakes were the only reasonable choice for tandem MTBs. I did finally bin my first set quite recently - actually I think that's a lie, I probably handed them on with the frame when I sold it. I think I've had 4 sets in all over the generations and the newest are very nice, plenty of power and good modulation though I've only had them a couple of years of light use so can't speak to durability yet.
Posted : 21/09/2021 2:24 pm
Whenever I bed new pads in, I check that they are powerful enough to lock up the back wheel and do a stoppie. I've never locked up a front wheel on a grippy surface, but if you can lift a back wheel off the ground, that's as much braking as you're gonna get. If they can't do this, they need more bedding in.
Posted : 21/09/2021 2:44 pm
IMO locking up a wheel is a bit of a red herring unless it is done under controlled lab conditions. There are just too many variables: surface, tyre grip, tyre pressure, brake temperature, disc size, pad type, rider/bike weight, gradient, environmental conditions…..etc.
Over the years I’ve had Shimano, Avid/Sram, Formula, Hayes, Magura, Giant and Hope disc brakes. The early ones were poor in comparison to newer models. I found Avid/SRAM a pain to bleed and I’ve had numerous piston swelling issues (including newish Levels). The lever reach adjust spring on Guide Rs also locked the front lever open whilst in the Alps - not fun. They had a nice feel but suffered from fade. I’ve had enough of SRAM brakes!
The last set of reliable Shimano brakes I had were some old XT M765. All the others since have suffered from calliper leaks. When working they are fine but grabby. Not an issue at speed but I prefer more modulation at slower speeds, particularly in techy/loose terrain. I’ve given up with Shimano brakes due to the leaks and throw away culture.
Having serviced a set of very old and neglected Hopes for a chap and ending up with brakes essentially as good as new I decided to drop the cash and get a set of Tech3/E4s a few years ago. I like them. Good, consistent, fade free power with great modulation and quiet operation. Easy and effective bleeding and a bite point adjust that actually does something. They also seem less prone to being effected by contamination, such as muck from being on the back of the car. Above all, despite being hammered they have been faultless and required nothing more than new pads and a precautionary bleed every year or so. If they do have an issue I can get the spares. And they are UK made! It would be nice if they were mineral oil though. Mine are black by the way! Having got on well with the E4s I recently got a set of Tech3/X2s and have been impressed by their power (loaded bikepacking trip and Lakes) and simplicity.
I understand people will have preferences over feel and looks but in my experience neither of my Hopes lack ultimate power. Those that say they have no power must surely have an mechanical or setup issue with their brakes? Anyhow, those new levers look good. Will be interesting to see what the real world difference is over the Tech3.
Posted : 21/09/2021 9:14 pm
I've defended Hope in the past on the grounds that they're not as crap as people say they are and that the reliability and consistency is preferable to the constant faffing needed to keep other brakes running on top form with their leaky calipers, plastic pistons and wobbly lever bushes. Even if there are more powerful brakes available the Hope's are nice to live with.
I was quite happy with my E4's for 4 years but now that they're gone I won't be rushing to replace them. I had a quick test ride on a bike with Code RSC's and the difference is staggering. Straight off the shop floor they make so much power for so little effort at the lever.
I'm going to put all the Avid/Sram, Juicy/Elixir/Guide related heartache behind me and see what they're like long term. If they flake out I might glance at Hope's if the new versions look any good.
Posted : 22/09/2021 12:18 pm
Reverse bleed – drain the master cylinder, squirt new fluid into calliper bleed port while making sure the hose is the highest point on the calliper. Drain master and repeat. Keep doing it until the fluid at the master cylinder is clean and bubble free.
Done with either a long hose on the syringe to the calliper, or with two people it’s an almost continuous process. Great way to teach your son how brake bleeding works.
that seems like more hassle than what I guess is the official way, open up the resevoir, loosen the caliper, pour in fluid while pumping the brake to push it through, catching the old fluid in a pot. Only done this once on my hopes, my old shimanos I was doing a bottom-up type bleed on a monthly basis, and the fluid coming out was black every month. lets also mention the shimano official bleed screw on thingy - not large enough to contain enough fluid to completely change the fluid in the brake, so you need to stop part way through, unscrew it and empty it, then carry on.
Posted : 22/09/2021 12:52 pm
I was quite happy with my E4’s for 4 years but now that they’re gone I won’t be rushing to replace them. I had a quick test ride on a bike with Code RSC’s and the difference is staggering. Straight off the shop floor they make so much power for so little effort at the lever.
I wonder if old pads, discs or unbled Hopes. I've got Code RSCs on a newish bike and agree - they're really good. But I just bled and changed the pads in my old E4s and still equally happy with them.
Job for later is to bleed the Guide's on K's bike as, despite being fitted new only back in May (and bled then) they still don't feel quite right.
Posted : 22/09/2021 1:20 pm
yep - agree. Code rsc are easily the best brake I've used out of hope e4, shimano 4 pot xt, magura mt5.
Posted : 22/09/2021 2:47 pm
Currently on shimano across the bikes (XT and Deore) and they're good. Had Hope X2s in the past (and some Minis) and they were good too. To be honest I don't feel that passionately about either of them. They're both fine. Yeah, they feel a bit different. But for an unfit old bloke bouncing down trails they're much of a muchness. It comes down to price for me.
That said, I once had a pair of Magura Marta SLs and they were incredible. I swear, they could talk to me through the levers. It was as though there were angels on the discs singing feedback to my fingers. But I was drinking a lot back then, so who knows.
Posted : 22/09/2021 2:57 pm
Looks like the tech4 is available in silver or black and just the mc cap, adjusters and bore caps on the caliper are in colours. Seem available in February looking at Evocycles site.
Posted : 08/12/2021 11:31 pm
Surely that's another plus for Hope - you can get them in different colours?
Posted : 09/12/2021 9:52 am
Look pretty good in solver, less so in black with colours
Posted : 09/12/2021 11:02 am
The colours look better the tech 3 way with the large areas in colour and black highlights.
Posted : 09/12/2021 11:23 am
A bold claim of "30% power increase from Tech 3"!
Posted : 09/12/2021 11:37 am
Can I get away with just a lever upgrade?
Was v close to getting some code rscs
£400 a set for hopes vs ~£300 for codes tho
Posted : 09/12/2021 11:44 am
 rone
Hope for years on the same bikes. Pads once a year on lots of miles. I've never had one fail, and performed scant maintenance.
Built properly.
Shimano basically just cheap and okay as mass produced item.
But not in the same league as Hope.
Posted : 09/12/2021 11:57 am
Other than when they swapped from 2 piston sizes to pistons of the same size the callipers don't seem to change much. A quick picture comparison and they look the same to me.
Posted : 09/12/2021 11:59 am
I'm sure I've said this a hundred times before but I love that Hope brakes last forever, and I don't love that some much cheaper, more disposable, less reliable brakes are much more powerful. If they can redress the balance I'd be back on board.
Posted : 09/12/2021 1:11 pm
Yep. Hope now lagging far behind the others in stopping power. They still have more colours though
Posted : 09/12/2021 1:45 pm
where can i buy just the leavers?
Posted : 09/12/2021 2:37 pm
I'm guessing but probably any bike shop in the country, same as all Hope stuff.
Posted : 09/12/2021 2:43 pm
All over the country with a big red bus?
Posted : 09/12/2021 3:55 pm
none available to purchase online as far as i can see
Posted : 09/12/2021 4:02 pm
Only complete Tech 4 brakes on the Hope b2b website currently. Tech 4 levers are not listed separately as a spare part yet.
Posted : 09/12/2021 4:44 pm
Chapeau.
Posted : 09/12/2021 9:54 pm
The black with coloured bits aren't doing it for me, I think the big white 4 on the mc cap ruins it, the silver with blue is the only one I'm liking at the moment.
Posted : 09/12/2021 10:56 pm
I am getting them in polished for my Shand (or is it tech 3 cant remember)
If they come with those horrid black caps tho they are going to be stripped and polished by me however.  Very unlike hope IMO to have something so tacky looking
Posted : 09/12/2021 11:03 pm
The gold is hideous as ever but I like the black on silver.
Posted : 09/12/2021 11:12 pm
That is orange, it wouldn't hurt if they brought back the gold and the gunmetal, these would look awesome in full gunmetal, as is, I think the full silver will be a good seller.
Posted : 10/12/2021 12:04 am
So Hope brakes are actually a thing then? I've never used them. As far as I know they're something that scammers attempt to 'sell' on Facebook marketplace.
Personally, I loved two pot XT and XTRs, but eventually they leak or the m/c pistons wear out. Now running Formula Cura 2 and Magura MT5 and frankly they both have more feel and probably a bit more power - but were definitely cheaper than Shimano (a major consideration for me).
Posted : 10/12/2021 1:16 am
It's been a long time since I last used Hope brakes, but must say I'm interested by these. They look well made, kinda like a cheaper option to Trickstuff.
Posted : 10/12/2021 6:29 am
Would a Hope lever work with a SRAM Code caliper? I'm thinking I'd get the lever feel I like from the Hope lever easier than I don't with the SRAM lever. I really like the Codes stopping power but the lever feel isn't my preferred...
Posted : 10/12/2021 7:37 am
I'll be interested to read the reviews on these to see if they've got the power up to anywhere near codes, maguras,shimano etc
Posted : 10/12/2021 7:51 am
Tech 4 come in silver/silver with just the Tech 4 in white.
Tech 3 silver would come with black lever blade, black top cap and bore caps, but you can buy a silver lever blade, master cylinder lid and bore cap separately if you wish.
Posted : 10/12/2021 10:25 am
That 30% increase claim puts them at 14% more torque than Saints, that's going off the enduro mag group test from a few years back, a 15% increase puts them level with Saints.
andybrad
Try a UKIP conference
Posted : 10/12/2021 10:45 am
😂😂😂 made my day George
Posted : 10/12/2021 10:54 am
Some people are easily pleased.
Posted : 10/12/2021 7:48 pm
Looking on Evocycles site they're only taking orders for tech4 E4 brakes, wonder how much power you'd get with V4 caliper and what its equal to in power. The prices for tech3 E4 are the lowest I've seen for a while. Never used Evocycles myself, are they decent.
Posted : 10/12/2021 7:56 pm
I see quite a number of Hope brake users V4,E4 on my Emtb forum. Those are 50+lbs bikes, yet theres no threads about them being underpowered.
Posted : 11/12/2021 12:47 am
I always want to get back into Hope brakes, but i've just stuck with XTs for years, or MT7s as they both do 1 finger levers that i like the feel off, these Tech4s look like they're not going to be comfortable with 1 finger braking, are hope doing any other lever blades, or is this it?
Posted : 11/12/2021 1:15 am
 grum
I don't own either brand now but I've generally found Hope brakes to be really good, and the Shimano brakes everyone on here spaffs over to be mediocre at best. I weigh 17 stone on a good day and did the Megavalanche with Hope brakes that never let me down. Maybe I was just lucky.
Posted : 11/12/2021 1:40 am
You wouldn't happen to have a vid of that would you ?. It's a 'race' i've always wanted to do, even thought the chances of me finishing so far back that most will be on the plane home by the time I come in 😆
I've watched a lot of the vids and its not embarrassing to see riders mincing it,walking mostly or dabbing a foot or ten , so if thats the case just post it up. Thats a bit like yacht racing, in that being seasick isnt something to be embarrassed about, its just a part of the game.
Posted : 11/12/2021 6:02 pm
Do you know what this thread is about? 😉
Posted : 11/12/2021 6:07 pm
I do yes. Its about the latest Hope enduro brakes.
Sorry,I'm missing your direction on this 🙂
Posted : 11/12/2021 6:53 pm
Biketart website now says summer 22 rather than spring 22
#+still no news on levers only option 😕
Posted : 06/02/2022 11:33 am
I have had Hope brakes for the last 12 years and can’t see by them. Takes 5 mins to set up each end and their ready to go. No issue with stoping power either and I weight 115kg before mtb gear goes on.
Posted : 07/02/2022 9:46 am
They're launching in March, won't be available as just lever for a while yet though, need to prioritise machine time for complete brakes while there's so many on order. Any Hope dealer can pre-order Tech 4s now.
Posted : 07/02/2022 10:18 am
Ooh
Thanks!
Posted : 07/02/2022 10:43 am
Pre-orders now are for late 2022. Yoiks!
Posted : 07/02/2022 11:37 am
Page 2 / 9
