Hope bb30 seized , ...
[Closed] Hope bb30 seized , help !!!
<span style="text-decoration: underline;">Won’t budge , and tool is near on useless it’s bent to buggery </span>
Posted : 02/12/2018 2:24 pm
PlusGas for a few days, then hammer taps on a tool. Short sharp shocks are far better at freeing stuff than sustained pressure IME.
Posted : 02/12/2018 2:56 pm
Where are you? I have the socket tool rather than the spanner. Actually, I have the spanner as well, but that's not relevant.
Posted : 02/12/2018 3:18 pm
I’m in the Cannock Chase area , where did yo get the socket type ?
Posted : 02/12/2018 3:41 pm
I'm in south Yorkshire but I got the socket type from Abbey Tools from, I think, Sigma Sports.
Posted : 02/12/2018 3:58 pm
Cheers Onzadog , is there any way removing without a specific tool , the bb is goosed anyway
Posted : 02/12/2018 4:31 pm
Great big Stilson Pipe Wrench. If you know someone who works in a chemical factory, power station, somewhere with a big maintenance department, it's the sort of thing they would have in the workshop.
Posted : 02/12/2018 4:56 pm
As above I had the same problem last weekend. Made a mess of it trying to move it with the right tool. Big pipe wrench and a few taps with a rubber mallet sorted it. I was a bit worried that I was going to damage the frame but it all turned out well in the end.
Posted : 02/12/2018 5:18 pm
Surely it's only the bearing that's goosed. Cup should be okay.
Until you get pipe wrench on it that is.
Posted : 02/12/2018 5:20 pm
All looks horribly mangled
Posted : 02/12/2018 5:25 pm
The cup had gone on mine. The tool sheered most of it off. First time I've ever had a problem with one. Usually just pull the bearing and replace but I needed to put a spacer in to get a bit more clearance with the chainstay.
Posted : 02/12/2018 5:43 pm
