trying to service a rear XC hub, it's probably 6 or 7 years old and not been serviced at all.
The end caps came off easy enough as did the freehub.
But I can't drift the axle out.
I split a bit of 2*4 last night, was using it to protect the axle end while using a 4 pound lump hammer.
It's now sitting in wd40 for a day, any other tips??
Posted : 19/07/2012 8:22 am
boiling water or heat
Posted : 19/07/2012 8:27 am
Drop an old bolt in the end of the axle so you can whack the bolt head with a proper hammer.
Posted : 19/07/2012 8:31 am
What he said ^^^^
Works a treat with a 2lb ball pein hammer
Posted : 19/07/2012 8:36 am
thanks guys, was going to use heat tonight anyway, good tip for the old bolt.
Posted : 19/07/2012 8:52 am
