Hope 10mm bolt in b...
[Closed] Hope 10mm bolt in bolts
5 Users
Morning, the bolts on my hope 10mm bolt ins are starting to round out, does anyone know if i can buy replacement bolts separately or do i need to buy a whole conversion kit?
cheers
Posted : 05/01/2017 10:05 am
Hope are pretty good with this sort of thing.
I would give them a ring and see what they can do.
Thanks,
Max
Posted : 05/01/2017 10:11 am
Give Hope a call, they should be able to let you know (might even send you some)
Looking at the bolts, it looks like the washer bit is separate, so you should be able to use a standard M10(?) socket screw.
Posted : 05/01/2017 10:12 am
Turnerfan1 - Member
I did that when I lost one of the wee spacers from my 10mm kit, they said "order a complete new kit from a shop". Cheers guys!
Posted : 05/01/2017 10:15 am
ok given them a call, turns out you can buy them separately, component part HUB 256.
strangely that is not listed on their kit conversion chart. found and ordered some now.
thanks all
Posted : 05/01/2017 10:33 am
I had the same problem with mine as i found that the hope ones to be a bit soft , so off down to the local nut and bolt shop and got some from them , this was about a couple of years ago , i think they cost me less than a fiver , still using them now . much better than the Hope ones .
Posted : 05/01/2017 10:57 am
