Home made GPS with ...
[Closed] Home made GPS with mapping and tracking
Same as someone else on this thread has done.
A standard SRAM/Garmin out front mount with this adapter attached to the phone (the the top adapter section cut off for a flat surface and then 2 or 4 screws to mount the phone or case to it) to mount it.
http://www.wiggle.co.uk/sram-quickview-computer-mount-adaptor/
[img] ?w=1500&h=1500&a=7[/img]
Posted : 12/11/2013 6:04 pm
I've now fitted the adapter as pictured above, using some pop rivets:
It works perfectly now though as I have a spare back for the phone (because of the 'accident' earlier in the thread...) I think I'm going to redo it with the adapter closer to the middle of the phone so that the phone sits a little closer to the stem. Or possibly as another alternative, to mount the phone landscape.
Posted : 25/11/2013 11:17 am
Sugru FTW when it comes to bodging handlebar mounts, surely?
Posted : 25/11/2013 12:31 pm
Would it be strong enough?
Posted : 25/11/2013 12:39 pm
Only one way to find out...! Might be better to use it to spread the load when using a small bolt to hold things together. However, it does have a small amount of inherent flexibility which could prove an advantage where there's a lot of vibration...
Posted : 25/11/2013 1:20 pm
I've been toying with acquiring a Cheapo "Galaxy Y" (£30 from Carphone whorehouse apparently ATM, ebay seems to be awash with them too but the bidding goes silly for some reason) it's got the required basics, GPS and Wifi and will take a micro SD card, stock it comes with a 1200 mAh battery, but higher capacity ones are knocking about on ebay, it can be charged from USB (say at work) run in no-sim/flight mode I think it would make a really good "poor mans Garmin"...
And I like the "Out front" mountings some of you have come up with...
The only issue being weather tightness, but that's easily enough overcome... Currently using my S2 (my main phone) as a logging device/bike computer and I bought a 3500 mAh battery to use in place of the standard 1600 mAh one it'll run for hours like that, but I'd still rather use a cheaper more basic alternative phone if I can...
I'm using the Sports tracker app for my "Cycle computer Display" (with Strava logging in the background too) and I've found it pretty good, but I might try IPbike, it looks pretty good too, getting a good, useful information display is pretty key IMO...
I guess that's the big advantage over a Garmin, you can run a pretty broad range of software on that one cheap device...
Also how many people are using a HRM with their Android phone?
And which ones?
I'm currently a bit confused over just what will be compatible with my Current S2 or for that matter any other android phone I might choose to use in the future, so far as I can tell a "Polar wearlink+" is the basic bluetooth model and will work with just about any phone, the H& is 5 kHz BLE enabled and there are differing reports of which phones and apps it will work with, ANT is probably out of the window for me, although some seem to think an ANT OTG jobbie and certain apps do the business...
My current thinking is I'll just bite the bullet, buy myself a wearlink+ and get an even higher capacity battery to offset the Bluetooth chewing through it. But it's not the ideal solution really and a wearlink+ or Zephyr HxM is still a few quid for what is basically old and inefficient technology...
Posted : 25/11/2013 3:08 pm
The Galaxy Y is (I think) smaller and more expensive than the Defy Mini SIM-free at the moment, but there's not much in it. I'd be inclined to go with a Defy Mini for the modicum of weatherproofing it has.
What tips do folks have for weatherproofing normal Android phones? Anyone got a weatherproof charging solution going?
Posted : 25/11/2013 3:22 pm
As I mentioned way, way up there ^
Top-tube frame bag with phone screen. Its fairly water-resistant, in heavy rain I put a cheap plastic bag over it 🙂
Like this:
And for charging, I connect it to a SP PD8 hub (on the road bike, I've now got a PD8-X on the MTB too) via a Kemo M172N adaptor.
Posted : 25/11/2013 3:30 pm
This looks good too:
[url= http://decide2ride.com/images/2013%20Mogi%20Max%20lav_8395%20lg.jp g" target="_blank">http://decide2ride.com/images/2013%20Mogi%20Max%20lav_8395%20lg.jp g"/> [/img][/url]
Posted : 25/11/2013 3:33 pm
Defy Mini for £30? where from? I can only find them around the £65 - £80 mark online...
To "weatherproof" a phone I've been using something like this for a while:
but it ain't a sexy solution...
For charging, I take it out and plug in the charger, are you looking for a way to charge it while left on the bike?
For the commuter I've got a big bar mounted bag with space for tools and tubes, and a phone pocket on top... that is brilliant, but bulky
I do fancy making my own "Out Front" type housing for a phone for my geared road bike just to keep things "minimal" yet functional and do away with the zip up carrier...
Posted : 25/11/2013 3:54 pm
@ir_bandito - sorry, late to the party as usual.
I've been using an UltimateAddons rugged handlebar case for my Galaxy S3 to run OruxMaps for a few months now, charging from an external USB battery pack. This works very well, other than the total lack of strain relief on the UltimateAddons USB charge cable, a problem I solved using Sugru.
Always interested in other solutions though, especially ones which might work when I've moved on from the S3... work's phone, so won't be with me forever.
Posted : 25/11/2013 4:44 pm
clubber; Garmin mount looks good, can i ask what pop riveter you used? Not used one before and feel a gap in the toolkit! (would be useful to fix mudguards, kids toys etc)
Posted : 25/11/2013 4:50 pm
No, they're both around this sort of price SIM-Free from what I can see. You can get the Galaxy Y for £30 on a PAYG contract from Carphone Warehouse.
Looking to get a dynamo and/or external battery charging solution rocking at some point, so cases with a power lead option are a plus, hence my going for the UltimateAddons solution.
Posted : 25/11/2013 4:53 pm
I like this idea:
http://getfinn.com/
Think I might try it out, review here:
http://road.cc/content/review/99482-bikecityguide-finn
Posted : 25/11/2013 5:09 pm
My Defy Minis have been on ebay and about £35-40 ish - I just set up an alert for one under £40 on buy-it-now. They come up periodically so just snap it up as soon as you get an alert.
acjim - Member
It's just a cheap rivet gun from ebay - £8 iirc. Rivets can be had for few quid. It's certainly a useful tool to have.
OT but I also have a rivnut gun which is useful for replacing stipped bottle cage bolts in frames.
Posted : 25/11/2013 5:41 pm
Has anyone tried using Sugru to bodge a SRAM quickview mount for a Defy? Any reason why I shouldn't just bond the adapter to the back of of the battery cover using superglue or Sugru?
Posted : 28/11/2013 10:06 pm
I'm not convined that a non-mechanical fixing (unless you're going going to use proper aerospace/etc type adhesive and preparation techniques) will ever be sturdy enough to hold a phone - they're actually quite heavy and subjected to a lot of rattling around on the bars.
Posted : 03/12/2013 12:32 pm
I've used some different adhesive solutions and none were sufficient.
I think the vibration from riding stopped it from being effective. There's probably a solution, but I'll stick with a screw being my main means of fixing.
Posted : 03/12/2013 1:35 pm
A decent PU adhesive / sealer, eg Sikaflex or Tiger seal, should give a good strong bond. With a few mm bed it would give resonable vibration isolation too.
I could do pull ups on 18" lengths of batton stuck to the roof of my camper conversion with the stuff.
Only draw back is it comes in big tubes so not efficient for small quantities.
Posted : 03/12/2013 2:20 pm
Check this out though: http://sugru.com/magnet-kit
Posted : 04/12/2013 5:13 pm
That looks pretty cool!
Posted : 04/12/2013 6:10 pm
Hmm, I might try this. No need to wait for the Sugru magnet kit to become available. N52 neodymium magnets from ebay, one SRAM quickview mount, and a pack of Sugru.
Posted : 04/12/2013 10:04 pm
Mind your credit cards near those magnets though...!
Posted : 06/12/2013 12:10 pm
This may also be of interest: http://www.decathlon.co.uk/en/product/~product_id=8294081
Posted : 11/12/2013 10:21 pm
Anyone given one of [url= http://www.amazon.co.uk/Hardwearing-Phone-Ericsson-Xperia-DURAGADGET/dp/B005UOMBOY/ref=reg_hu-rd_add_1_dp ]these[/url] a go?
Posted : 13/12/2013 12:17 am
That looks very like an UltimateAddons soft case:
http://www.play.com/Mobiles/Mobile/4-/40892177/744371764/-/ListingDetails.html
I have one of their rugged cases for my Galaxy S3, which I rate very highly other than one aspect.
I use the compatible charger cable with an external USB battery, and the strain relief on the power plug is non-existent. The lead broke on my second ride using it. I got a replacement and beefed up the strain relief and waterproofing of the plug using Sugru.
Posted : 17/12/2013 8:22 pm
holy thread resurrection! checking in as I'm currently playing with OruxMaps on my Moto G (and trying to avoid dropping hundreds of pounds on a pointless Garmin).
Posted : 17/06/2014 1:47 pm
I'm not sure the garmins are pointless - battery life means that they're always going to have one big factor in their favour for longer rides.
I killed my defy mini - water got in unfortunately but I have a cheap Defy (not mini) that I'm going to try once I get round to it. I have found though that in the wet, the screen registers as though you're touching it with your finger and goes a bit crazy. Need some sort of touch screen lock I reckon.
Posted : 17/06/2014 1:57 pm
yeah fair enough, not pointless, more I'm trying to establish where the sweet spot is on the cost/utility spectrum (without spending 500 smackers if it's not necessary for my use case)
partly it's just fun messing with the widgets I've got
Posted : 17/06/2014 2:21 pm
And that's the bit I quite like 🙂 My garmin is better though but as more apps become available, that may change.
Posted : 17/06/2014 2:22 pm
Download your mapping onto your phone and then put it into Airplane mode while using it for navigation, it will use absolutely scads less battery that way. Only turn on comms or Wifi if you need to. Use an external USB battery pack to recharge overnight on multi-day trips, or just keep the internal battery topped up all the time.
Posted : 17/06/2014 2:27 pm
how are Garmins for readability in bright sunlight?
Posted : 17/06/2014 2:56 pm
It's the screen backlight that kills battery life IME.
My 605 is fine in bright sunlight. Not that we seem to ever have sun 🙂
Posted : 17/06/2014 3:08 pm
I use a 5000mAh USB battery pack with my Desire HD for navigation. The longest route I've done so far took 7 hours and I still had full phone charge and one bar of life left on the battery pack.
I keep mine in a crossbar bag with phone window and the battery in with it so everything stays protected from the elements.
Posted : 17/06/2014 4:36 pm
 rjj
Just got a Samsung Y for £22. What is the agreed best way of attaching to bike?
Cheers.
Posted : 07/07/2014 11:33 am
 rjj
Anyone with an update?
Posted : 08/07/2014 10:07 pm
The sram / garmin adapter works well per clubber's earlier post.
Posted : 08/07/2014 10:56 pm
I used a phone case and a Hope light mount, but I did trash the first case.
Must get round to mounting the second one properly 🙄
Posted : 09/07/2014 9:12 pm
Here are some pictures of my Motorola Mini , with a mount I made from a rubber case, some tin and some sugru, mated to an older style garmin mount. Chatters a bit on rough down hills, but stays put, and good and readable. Use Oruxmaps.
Posted : 09/07/2014 10:13 pm
This might be of interest:
http://www.digitaltrends.com/mobile/best-waterproof-phones/
It mentions the Kyocera Hydro phones, the original of which is now available for buttons on eBay:
http://www.ebay.co.uk/itm/181346922314
Not stellar spec but easily adequate for a bike GPS/phone I would have thought.
Posted : 10/07/2014 9:29 am
 rjj
I am going to try and attach mine with one of those silicone bands and see how it gets on.[url= http://www.amazon.co.uk/Random-Silicone-Bicycle-Cycling-Navigation/dp/B00B6YZDVU ]Link[/url]
Posted : 14/07/2014 12:26 pm
I`m really stuck,
haven't used this (Orux Maps)for ages, forgotten everything and cant get back to the basic settings ?
I have buttons too big on the screen but cant seem to find the basic settings again to change the display set up ?
I`ve now wasted 2 hours of my life, got an Irate mrs, and a big ride on tomorrow which I cant get to display in a meaningful format
Please stop me going out and buying a garmin !?!? 🙄 🙁
Posted : 19/07/2014 1:22 pm
Great idea many thanks for it, I bought a defy mini on eBay (as new re cons now down to £30, small scratches £24!). Then I got hold of the hope light bracket.
Rather than bolt to the phone direct this is bolted to a case - it's bendy meaning there's room for a big washer which will hopefully spread the load and that the phone retains its waterproofing.
Seems pretty stable so far.
I'm using viewranger as can easily plot and upload routes from my Mac.
Posted : 20/11/2014 10:02 pm
[b]Argh[/b], my Defy has stopped picking up satellites and won't work with oruxmaps anymore. Anyone had a defy and fixed this?
Posted : 21/02/2015 10:31 pm
Given that you can get them cheap, probably just get another one....
Posted : 21/02/2015 10:47 pm
Thanks, I did think of that but given the slight hassle to setup a garmin plug I think I'll buy an garmin edge touring instead - pretty inexpensive from Germany
Posted : 22/02/2015 11:01 am
have you tried using the GPS Status app?
Faster GPS app miight be worth a look as well, you can use it to easily reset your NTP server and region settings if they have gone wonky for some reason.
Posted : 22/02/2015 12:40 pm
Yes I did try that, no joy, it's possible that it will return but it dropped me in the poo the other day (had to ride an unknown route which worked ok but could have been a real pain). It's been a good and very cheap way to try digital mapping though.
Posted : 22/02/2015 1:46 pm
Acjim -
I had this happen to me a week or so ago . Rebooting seemed to help. I'm now using Locus rather than Oruxmaps, and find it more reliable.
Posted : 22/02/2015 2:04 pm
Sorry folks but my links never work....
So, if you are looking for a secure way to mount your smartphone, have a look at Edinburgh Bicycle Co-operative
Revolution Smartphone Holder
Click to enlarge
(6 reviews)
Free collect
in store >
Exclusive >
Find out more >
Handlebar stem-mount Smartphone holder.
Makes your phone accessible when you ride.
Especially useful if you use your phone as a GPS.
Colour Price Availability
Black £2.99 In Stock
DescriptionImagesTechnical DataReviewsQ & A
Average: 3.5 / 5
Submit a review
weordie
Newcastle
Great little smartphone holder. Easy to attatch to the bike as well. Emphasis should be on little though, won't hold a phone like a Galaxy S4 in a secure way (the top doesn't close over). If you have a smaller phone though it'll be great. Should say in description it won't fit newest models though.
duckwaj
East Sussex
What at bargain! easy to fit, works great and pleasantly understated. Rivals start at about £50. Buy it, its a no-brainer
Matt W
Warwickshire
A great idea in theory and having had a bad experience with a less than solidly attached phone holder, this looked ideal. The construction is solid however Edinburgh Bicycle need to point out that this is not suitable for angled stems as the mount does not sit correctly on the headset. I do feel that I have been misled into thinking this product would work on my bike.
chramm
Derby
Just to mention that I bought it for a Nokia E72 and it fits perfectly.
m1sterbee
Fife
I thought this might be a bit gimmicky - but it's not.??Easy to fit onto the steerer, had to relocate the bell on to the fork on the bike but definitely worth it.??I use the cyclemeter app to track my regular commute - this is great to keep an eye on progress. It's secure, weatherproof and just really simple. ??Fits the iPhone 4 perfectly and I fitted it to a Specialized Tricross Sport.??Great for receiving that "can you pick up milk?" text or "you forgot your wallet" - now you can react to these messages in real time rather than view them at your journeys end after retrieving phone from your pocket.
unknown
Darlington
I have been looking for this device for some time for my wife and was thrilled to find one on a notification from edinburghbicycles. I was just about to order one when I spotted the footnote explaining that it fits to the steerer/spacer on modern bikes and not it seems to the stem or handlebars. No good then, as it needs to fit to the stoker handlebars of a tandem.
That's the best I can do 😮
Posted : 22/02/2015 3:55 pm
I'll have a go with locus, gps fix doesn't show a fix though
Posted : 22/02/2015 5:12 pm
Page 3 / 3
