Hi Ho, Hi Ho Its of...
[Closed] Hi Ho, Hi Ho Its off to niche I go
So the Krampus is out for a test ride tonight. I'll try and take some Krampus shots in the wild, if it doesn't bite me or send me to Hell first.
Got a new logo for the fork....
Thanks to Slik Graphics for an amazing job
Posted : 22/08/2013 1:55 pm
My instant reacation was " OHHHH, nice" like to hear more.
Posted : 22/08/2013 1:56 pm
What do you want to know....
Posted : 22/08/2013 2:02 pm
Why 2 ls in Lefty?
Posted : 22/08/2013 2:09 pm
Project321 Hubs (industry9 internals in rear hub)
Project321 clamps
Thumbprint Tuning Hefty fork with effectively 90mm travel (axle to crown is exactly the same as Krampus rigid fork, and it has new RockShox air cartridge with a lockout)
Rabbit hole rims
120tpi Knards 3"x29" with 20mm? Travel ๐Ÿ˜€
32t narrow wide from raceface
IMC chain
CK headset
Everything else from previous bike
Is the Lefty modified then?
Posted : 22/08/2013 2:10 pm
Yes, it's a Max upper, 110 lower to be able to fit new cartridge. Don't want or need small bump sensitivity, the tyres will have that. now I just need to set it up with the right tyre pressures and fork pressures, but it will be fun doing it
Posted : 22/08/2013 2:12 pm
 nbt
[quote=nick1962 ]What do you want to know....
Why 2 ls in Lefty?
It's Hefty.
HTH
HAND
Posted : 22/08/2013 2:13 pm
Tony at Thumbprint built it up and applied his special brand of magic on the needle bearings
Charlie supplied coffee, workshop, conversation, Dave and Krampus build kit
Nice. You didn't need new crowns for tyre clearance then?
Posted : 22/08/2013 2:37 pm
I did. They are a project 321 set with 1 1/8 steerer. It allows your to spread the whole fork out to the left to compensate for the dishing of the wheel to give enough clearance to use the Rabbit Hole rimes and Knard without a worry. TBH the dishing is a lot, although the tension in the spokes is balance on either side of the hub and if there is a need to rebuild the wheel, I would bring it back a little, as it currently has about an inch of clearance from the stanchion with the tyre fully inflated. it is all aligned nicely.
Posted : 22/08/2013 2:58 pm
I see.
Brilliant. Looking forward to seeing photos of it in action. ๐Ÿ™‚
The slight downside is you've given me all sorts of (expensive) ideas now...
Posted : 22/08/2013 3:03 pm
Slight? ๐Ÿ˜€
Posted : 22/08/2013 3:25 pm
I was going to do that on my build, but thought you could just fit it all together as normal, with dishing the wheel to the right a bit, obviously not. Need a rethink now, bugger!! ๐Ÿ™
Posted : 22/08/2013 5:00 pm
Krampus lives! It's a great fun bike. Glad I went for 32t rather than 30t currently seems perfect ratio range and bit one single drop if the chain ( and I wasn't hanging about)
Posted : 23/08/2013 8:37 am
What problem is the heavily modified lefty solving for you?
Posted : 23/08/2013 8:45 am
The rim is 50mm wide. The inflated knard is 770 wide on the rim. I would get a dirty great big hole in the stanchion and a ruined tyre. So, the front week is offset(using one side spoke wholes which are 5mm from center. The crowns on originals have a tooth that aligned the spindle of the fork in a groove. Special ones don't have this so you can rotate the stanchion as you spread the fork out wider to compensate for the dishing of the wheel.
Posted : 23/08/2013 8:54 am
nbt - Member
nick1962 ยป What do you want to know....
Why 2 ls in Lefty?
It's Hefty.
HTH
HAND
I read it as Llefty too - I thought it was a Welsh thing
Posted : 23/08/2013 8:59 am
Got you. Cool mod
Looks a great bike, hope you're happy with it!
Posted : 23/08/2013 9:04 am
๐Ÿ™‚
I have no issue with creating confusion. I'll get enough of that from having a lefty and having a fat bike.
I imagine if I ever ride Swinley small children will be sheltered behind their parents as all things different cause fear and panic
Posted : 23/08/2013 9:05 am
geoffj - Member
nbt - Member
Why 2 ls in Lefty?
It's Hefty.
HTH
HAND
+2
Nice bike, crap sticker ๐Ÿ˜ฎ
Posted : 23/08/2013 9:07 am
It rides brilliantly! It picks up speed alarmingly and I will have to get used to the way the bike wants to bulldoze the trail whilst actually being really nimble too. I have to admit to being a little paranoid about being wedged between trees at the moment, but I'll get passed that....or not ๐Ÿ˜ฏ
If i'm reading that right you're rotating the clamps outward to get more sidewards offset?
Does that not then alter the forwards offset of the fork and bring everything further back.
I though the 321 clamp was wider to get the tyre clearance?
Looks good BTW.
Posted : 23/08/2013 9:31 am
Looks like a great build and a proper fun bike to ride that.
I too wasn't sure what function the Lefty was performing, but if it works in your environment then it's a good fit and as you say, will cause children to point and (laugh) s**** or pose the question "where's the other leg" (it was a recurring question I had when I had my lefty)
Doesn't look dirty enough, suggest you ride it harder ๐Ÿ˜†
Posted : 23/08/2013 9:37 am
That looks superb. You must be a very happy man ๐Ÿ™‚
if you don't mind me asking, how much did the Hefty cost?
Posted : 23/08/2013 9:43 am
The decal or the fork ir_bandito? Can get more made if you want a decal. in regards to the Hefty fork, contact [url= http://www.thumbprinttuning.co.uk/ ]Tony.[/url]
Bikebouy I live in the south....it's not very muddy down here, but a little flat. Tbh I was 5 mins into the ride and had stopped to tighten up the bolts etc as it was the first ride....big smiles, as it rides brilliantly. It climbs in a way I have only experienced back in the day when 1" threaded headsets were all the rage and Orange still made all of their bikes in the UK, suspension at both ends was a pipe dream, and we all had an embarrassing relationship to dayglo Lycra.
Singlespeedstu the overall wheelbase is only a tiny bit shorter than the rigid Surly fork now, where as if you used the standard clamps I am fairly sure that the effective wheelbase would be longer than Surly intended. Also, the offset in the front wheel is really playing it safe. I have massive clearance as you can see in the pics, so if you wanted to do this kind of build I have been given some spoke lengths by the wheel builder, Bungle in Wareham, that would be less extreme, so the clamps wouldn't need to be so far to the left. With the lock out activated, it rides really well, but with the Lefty working it soaks up everything and grips even more. it accelerates with an unnerving sense of being strapped to the outside of a 50 tonne truck falling off a very tall cliff. It's awesome
Posted : 23/08/2013 10:44 am
๐Ÿ˜€
Thanks for your answer.
Goes off to look at Leftys.
Posted : 23/08/2013 10:48 am
I meant the fork, rather than the decal....
Posted : 23/08/2013 10:55 am
If you already have a lefty max from that period then it will be cheaper, but only (there is a Link if you look in my previous post) to Tony, who built the fork for me. The [url= http://www.project321.com/products_bike-lefty-adapter-clamp.php ]project321 Clamps[/url] were $200. I would recommend both companies as they both were great to deal with, and if you talk to Tony, ask him about his gravity bike....it's bloomin fantastic!
Posted : 23/08/2013 11:02 am
it's not a proper fat bike though is it? any desire to go full fat?
It's fat enough for now. I don't live in a snow bound part of the UK, and beaches are a long way from me. They look brilliant. Dave at Charlie's cave was building up a Moonlader as I was fettling. it was khaki green and looked like a hoot. I have a need to have a go, and Charlie wants a play on my Hefty, so I'll see. Coffers empty for now ๐Ÿ˜€
Posted : 23/08/2013 11:06 am
It's bad and wrong, but this bicycle is making my willy tingle in a nice way. ๐Ÿ˜ณ
Posted : 23/08/2013 11:09 am
I have absolutely nothing to add to the above post ๐Ÿ˜†
Email sent to Tony.
And to be fair, Pimp's willy tingles at some pretty odd things...
Posted : 23/08/2013 11:12 am
it's weird, I think fat/ semi-skimmed bikes are pointless, but I really really really really really want to have a go on one.
Posted : 23/08/2013 11:13 am
I felt the same way. then I rode the Debora Charlie the Bike Monger...rode Franks Tank. I didn't stip grinning the entire ride. Be warned, only try one if you have physical space for another bike....all other facts are a moot point anyway
Posted : 23/08/2013 11:21 am
[list]Oops Debora...damned predictive text. In the Interest of saving my marriage I would like to state I don't even know anybody called Debora....should have been Krampus....how did that convert to Debora????
Posted : 23/08/2013 11:42 am
does not compute. there is always space for another bike ๐Ÿ™‚
Posted : 23/08/2013 11:46 am
