Help:Talk to me abo...
[Closed] Help:Talk to me about going tubeless!!!!
[#7946934]
Firstly I have a set of Mavic crossmax slr wheels and just bought a pair of Bontrager XR2 Expert tyres which are tubeless ready. I have the valves ready if I want to go ahead. What's the best way to do it and how much sealant required. Tyres are 2.3 front/2.2 rear. Comments appriciated.
Posted : 15/07/2016 9:22 pm
About 90ml will do nicely in a 29'er tyre, should go up with a decent track pump.
Simples
Posted : 15/07/2016 9:34 pm
Put tyres on as normal, pump up until seated ( usually pop or bang 35psi+) let down, unscrew valve, pour / inject sealant in via valve hole 60ml-90ml. Screw valve back in. Turn tyre through 180 degrees ( valve at top ) Pump up until seated, shake, twist, bounce, roll tyre round. Bingo. Drop pressure to desired. Ride.
Posted : 15/07/2016 9:41 pm
I'm running old school 26" tyres so 50mls in each tyre. Best to use co2 inflator initially?
Posted : 15/07/2016 9:45 pm
Depends on the sealant I think.
Never had an issue with Slime but I think Stans is not co2 friendly.
I only use CO2 rarely. 9/10 times track pump does the job.
Other advice above is good.
Posted : 15/07/2016 10:00 pm
Alright thanks for the comments.
Posted : 15/07/2016 10:04 pm
Watch the YouTube videos either joes sealant or stans and use either the yellow tape or gorilla tape
Posted : 15/07/2016 10:52 pm
 mrmo
i currently have my bike lying on its side and pissing sealant out of the sidewall of one tyre. hopefully it will seal.
Just thought i should mention.
The tyre went up fine with a track pump, just has a few "leaks".
Posted : 15/07/2016 10:59 pm
Don't use co2, the cold blast is really bad for the sealant. For home use the air shot is a great thing for stubborn combinations.
Posted : 16/07/2016 3:44 am
I used a bontrager charge pump yesterday to get 26.5x3 TLE tyres to seat on scrapers. Satisfying *BANG* when they went on. Then unscrewed valve, added stans & reinflated, did the stans shuffle & spin to coat the inside (more important on a used tyre) refitted wheel to bike & went for a 30 mile ride
Posted : 16/07/2016 6:30 am
No tape needed, they're UST rims.
Posted : 16/07/2016 7:10 am
With a dedicated rim and tyre I wouldn't anticipate any issues. I have never had to use more than a track pump to inflate any of my tyre or rim combinations.
Posted : 16/07/2016 7:15 am
rOcKeTdOg - Member
POSTED 1 HOUR AGO # REPORT-POST
You've added an unnecessary step there. Just put the sealant in right at the start, pull the lever, dance/shuffle/whatevs, adjust pressure, ride
Posted : 16/07/2016 7:42 am
2nd the airshot for tricky or loose combinations. Brilliant thing. Much more effective than a compressor.
Posted : 16/07/2016 9:08 am
