HELP....2010 Rock S...
[Closed] HELP....2010 Rock Shox Revelation Race problem?
Just setting up the Revs today (bought used from STW user), come across a problem......
On setting pressures/sag i let all the air out of the Neg section so i could set the Pos section first, the Pos section has 130 psi as a start but i cannot move the fork at all !!!!!!!. Rock solid.
Put some air back in Neg section 100psi and fork moves again??????
Is this a sign of serious problem?
Not used the forks since buying them a few weeks ago as they are on a frame i'm building up.
Help ๐Ÿ™
Posted : 03/08/2011 8:21 am
No - the negative air is effectively a spring pushing the fork down. lots of positive air and no negative air will make for a very hard fork
Try letting all the air out of both chambers and see if the fork moves?
Posted : 03/08/2011 8:24 am
Exactly the same on my reba 120mm teams, and on my mates revs. Not a problem. I have never understood the guidance to set sag with no air in the neg chamber, as as you have found out it is impossible.
I just put a bit in, like you, and work from there.
Kev
Posted : 03/08/2011 8:26 am
Also seems like quite a lot of pres. for Revs. I am 92kg and have gone down to 85+ 90- on my 150 Rev Teams.
Posted : 03/08/2011 8:30 am
Fivespot.....literally is just a starting point i'm 95kg.
I got the idea of no Neg pressure and set Pos first from previous threads from here.....were they wrong because it just didn't work on mine.
Posted : 03/08/2011 8:32 am
With the 2010 onwards Rev's you have to set the sag with equal pressures. Its changed slightly from the older ones where you should set sag with +Ve only.
Set sag with roughly equal +/-Ve and then tune the -Ve for feel.
For reference I'm 72kg and I have 85+ 75- on my 2010 Rev Teams
Posted : 03/08/2011 8:35 am
Thanks folks, got myself all worked up and thought i had a broken fork..........and relax.
Posted : 03/08/2011 8:36 am
