i have a rockshox revelation with a pushloc. usually when you push the lock it closes nicely and then when you click it again the blue compression dial would snap back opening up the fork again. For some reason the blue ring is really stiff even to turn with your fingers. Its almost like a spring has gone or something any ideas whats causing this?
Have you tried a bit of lube. Triflow or a squirt of dry lube on the dials/knobs. Also check the pushlock cable is running smoothly in it's outer.
tried all that. thing is if you remove the poploc cable the blue knob still used to pop back but now it does nothing
something internal must be broken then without disasembling hard to say what.
damn that doesnt sound good. Ok so ill have to send them somewhere i suppose
