Help with crossmax ...
[Closed] Help with crossmax 27.5 hub spacers
AAAAGGGGHHHHH!
I have this wheel that needs an adapter, to make it 142x12...
Crossmax rear wheel
can't bloody get it right, can I! I've tried these adapters and the wheel doesn't fit.
Crossmax hub adaptors
I know it's not the gold ones, they came with the wheel and are the boost adapters, the red ones aren't much thinner - both of these are too wide for the 142mm dropouts, and the black ones are a mystery - i've no idea how they fit onto the axle.
Could anyone offer some advice? I've nearly spent as much on adapters as I did on the wheel!
thanks muchley
Posted : 10/08/2020 8:45 pm
If it came as boost then it probably won't ever fit as the whole hub shell will be wider.
Posted : 10/08/2020 8:57 pm
What nixie said. If it's a boost wheel then you can't adapt it to fit a 142 frame.
Posted : 10/08/2020 9:12 pm
if it's boost, wouldn't it be 148x12mm as standard? without any adaptors?
I didn't realise that it might be boost flange spacing, I bought it new, off eBay as a 135/142 hub.
... that would mean the disc rotor would be off too...bugger! ๐Ÿ™
Posted : 10/08/2020 10:12 pm
The adaptors are end caps. You need them to help protect the bearings and also provide a larger clamping surface. Was it the whole wheel you bought? Time to talk to the seller or sell it on as the correct description.
Posted : 10/08/2020 11:40 pm
