Help with a Heckler...
[Closed] Help with a Heckler head tube issue please
Right then, iv'e got a 2007 Heckler and have just fitted an FSA Orbit XL 2 headset and at first I thought I hadn't got it all the way in right so gave it a few more persuasive hits and its still looks a tiny bit not in... let me explain, at the front of the headtube where the Santacruz sticker is it looks like there is a tiny little gap maybe 1mm more than at the back of the headtube (looking from sitting on seat) after installing the third time and now knowing for a fact its all the way in and sitting flat my theory is this... I think the either the headtube hole where the forks go through isn't pefectly dead centre (from the factory) or... the front part of the headtube is ever so slightly thicker in gage to the back.
So to recap the back looks like it sits slightly lower by maybe 1mm in the headtube than the front or the alloy is slightly thicker PHEW!!!
Does anyone have a clue what I mean? and does anyone have a Heckler with the same issue? or am I being so bloody anal about it being 1mm higher it the front than the back and need my head sorting out ๐Ÿ™
Suggestions ๐Ÿ™‚
Posted : 04/09/2010 10:03 pm
Do you mean the hole may not be reamed centrally in the headtube, or that your headtube doesn't appear to be faced?
Its difficult to tell from your description.
Posted : 05/09/2010 7:38 am
A picture speaks a thousand words...especially one in focus, using macro mode if necessary ๐Ÿ™‚
Have you tried assembling everything and seeing if the bars spin with no tight/loose spots?
Posted : 05/09/2010 8:48 am
All SC frames look like this. The head tube is butted and that is what you are looking at.
Posted : 05/09/2010 9:33 am
I'll get a pic up later, but its hard to explain its almost like the front part of the headtube is a tiny bit thicker than the back, are all hecklers like this?
Posted : 05/09/2010 3:56 pm
Pic needed. If the headset is seated then don't worry.
Posted : 05/09/2010 4:08 pm
Hoooray! just took the headset cup off AGAIN! and it is indeed factory made so there is some reinforcement at the front so that means all is spot on ๐Ÿ™‚
Thanks anyway guys ๐Ÿ™‚
Posted : 05/09/2010 5:02 pm
