Help! Rounded self ...
[Closed] Help! Rounded self extracting Middleburn crank bolt..
[#5955349]
The right hand side self extracting crank bolt has rounded off on my X type cranks and I cant remove the crank arm. Any ideas how can remove it?
Posted : 12/02/2014 7:13 pm
Would a stud extractor work?
http://www.wikihow.com/Use-a-Screw-Extractor
Posted : 12/02/2014 7:50 pm
Hammer a suitable sized torx bit into it and that should shock the stretched bolt and the torx splines may grip the edges enough to loosen it, that's if you already have a suitable sized torx bit and preferably of 3/8th drive.
A T50 torx bit may grip the rounded head otherwise an m10 spline may fit, i have x-type cranks and a T50 fits the head of the bolt, the m10 spline would prob fit if i had a rounded head and resorted to hammering it in
And don't use normal allen keys, get a set of hex socket bits.
Screw extractors will not work as the depth of the bolt head is not enough, and a set of decent quality bolt extractors cost more than a set of X-type cranks.
Posted : 12/02/2014 8:09 pm
would removing the cap help?
Posted : 12/02/2014 8:30 pm
Ive used a stud extractor on one they are made of the most useless soft alloy.
Posted : 12/02/2014 8:37 pm
Thanks for the info.
I've tried removing the cap with a peg spanner but it wont budge.
Will look into the stud extractor and torx method.
Posted : 13/02/2014 9:20 am
If you can remove the self extractor cap, the torx is the most obvious answer, failing that, drill time!
Posted : 13/02/2014 9:58 am
