HELP!!! ~ Reverb Pa...
[Closed] HELP!!! ~ Reverb Part Needed
5 Users
 P20
I've bust part of ahsats reverb when servicing it..... bizarrely inputs only part on the diagram that doesn't have a part number! 😕
It's an A1 or A2 stealth post. On the rockshox service videos it is referred to as the seal head. (Not the inner seal head). Outer seal head doesn't appear to bring up any results either....
Any ideas?
[url= https://c1.staticflickr.com/5/4209/35143606886_22163ba0da_b.jp g" target="_blank">https://c1.staticflickr.com/5/4209/35143606886_22163ba0da_b.jp g"/> [/img][/url][url= https://flic.kr/p/VxwaWE ]Untitled[/url] by [url= https://www.flickr.com/photos/66452821@N00/ ]ritcheyp20[/url], on Flickr
Posted : 08/06/2017 8:09 pm
 P20
Anyone??
Posted : 09/06/2017 9:57 am
 P20
Another desperate bump. I'm awaiting to hear from Zyrofisher
Posted : 15/06/2017 4:57 pm
One of these?
https://www.bike24.com/p2184692.html
(The 2015 parts catalogue has the part you arrowed as #13)
Posted : 15/06/2017 5:07 pm
If you check an older manual it is shown as part no 13 - 11.6815.030.010 lower barb assembly kit. Seems to come with the bottom bit marked as part 13 on your manual as one thing.
Edit: beaten to it!
Posted : 15/06/2017 5:08 pm
SNAP!
How did you break it, BTW?
Posted : 15/06/2017 5:10 pm
 P20
The 2015 seems to be the same diagram from what I can see.
Tilly unfortunately the bit isn't in that kit.ts the part that is between 13 and 37 in the pic and threads in to the inner shaft.
As to how it died..... not sure to be honest. I'd had my post apart (same problem, sagging under pressure) and back together no problem. Did the same with this one, pressurised it and it sucked itself down!! Toook it back apart and somehow bust this bit.
Posted : 15/06/2017 8:13 pm
Post a picture of the part. Looks suspiciously like its part of the piston kit if it's not in that part linked above.
Posted : 15/06/2017 8:41 pm
Ouch, that's awkward. It seems to be one of the few bits that isn't listed as a spare part. Maybe get in touch with one of the rebuilding companies to see if they have a used one to spare if SRAM don't come through. I can't see that it's a wearing part, so anyone that scraps posts off might have one.
Posted : 15/06/2017 8:55 pm
 P20
Yeah I'm keeping an eye out for bust reverbs. Checked the non-stealth on the cotic and it's different limiting my options. Good idea to try the service companies, cheers
Posted : 15/06/2017 9:13 pm
 P20
TF Tuned have sorted the problem! Spoke to one of their technicians who had one kicking around in his spares drawer. Even gave really good advice on how to prevent damage after admitting he'd spannered a couple himself and that it was pretty soft. Done for the cost of the postage!
Posted : 24/06/2017 12:17 pm
Go on, then - what's the advice?
(Glad that you're sorted!)
Posted : 24/06/2017 5:21 pm
 nach
(Bookmarking because I want to hear about this - I think I know the part and have seen two different approaches to undoing it in SRAM's videos).
Posted : 24/06/2017 9:31 pm
Send it to TF tuned for a service next time :p
Posted : 24/06/2017 11:47 pm
