HELP: Removing squa...
[Closed] HELP: Removing square taper bb's
The ones with plastic cups with flanges (titter) with 6 notches in them that someone else has tried to do and made the square shapes more rounded through using the wrong tools.
Anyone help?
Tim
Posted : 08/06/2011 2:26 pm
http://cgi.ebay.co.uk/Campagnolo-Bottom-Bracket-English-Thread-Square-Taper-/220795114237?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item33686a12fd
Like the above with plastic cups and similar shaped notches.
Posted : 08/06/2011 2:27 pm
Drift/centre punch and hammer?
Posted : 08/06/2011 2:30 pm
Tried gently but it started damaging the cup and I wanted to source other solutions prior to going CAVEMAN on it.
Posted : 08/06/2011 2:32 pm
if there is nothing left to grip a big pair of molgrips or stilsons might be your best chance.
Posted : 08/06/2011 2:38 pm
Heat and cooling a few times bit of a soak with penetrating oil and patience.
Posted : 08/06/2011 2:39 pm
Soak in lots of releasing/penetrating spray over several days
Then pipe freeze spray followed by hot water ( a few times)
Disclaimer: freezing spray may crack your paintwork
Then more penetrating spray
Get a high quality tool (some of them are terrible) that fits properly Make sure it is one that will work with the flats of a large spanner (rather than a socket drive one) Reason for this follows....
Bolt the tool into the square taper (using a washer over the end of the end of tool) to stop tool jumping out of BB teeth (I do this as matter of routine now on square tapers)
Before you apply force, heat BB shell up with a blow torch
Disclaimer: this will damage your paintwork
Give it some welly with your large adjustable spanner OR better ...clamp the flats of the BB tool in a well mounted vice and turn the frame. Watch out for the vice breaking!
Before/in case you were going to consider it - do not use a hammer on adjustable spanner (the adjuster worm will break)
If all of this fails (ie the teeth strip) and you really really want to save the bike, then your last option will be to weld a socket to the BB and then use a long extension bar (worked for me after LBS broke 2 vices trying to get one out)
Posted : 08/06/2011 2:46 pm
Fluff - nice idea but wrong type of BB!
Nice ideas the rest of you. Nothings working at present.
Posted : 08/06/2011 2:48 pm
http://www.parktool.com/product/bottom-bracket-tool-bbt-4
I think I need one of these.
Posted : 08/06/2011 2:50 pm
drill a couple of holes in the face of it and put some self tapping screws in so you can then use a screwdriver/etc between the screws as a lever to undo the thing.
Posted : 08/06/2011 2:51 pm
Luke. Now that's a tip top idea mate.
You are one step ahead as always :O)
Tim
Posted : 08/06/2011 2:53 pm
I've got the tool to do it, better than the park one, where are you?
You need one of these, holds firm by screwing into the BB where the crank bolt goes (can't slip then)
Tiger - Lewes, East Sussex.
Now I bet you're up North somewhere. Aberdeen or one of the islands off Scotland :O)
Posted : 08/06/2011 2:54 pm
[i]You are one step ahead as always[/i]
I did try and include the use of an inappropriate tool as a lever 😉
although having done this I'd probably spend an hour trying to turn it the wrong way...
Posted : 08/06/2011 2:55 pm
Wales then looking at your profile. Not to worry. The BB needs to come out and jump straight in the bin so I'll go and get the drill out.
Posted : 08/06/2011 2:56 pm
Near Heathrow, in fact just a bit south of Heathrow.
If it's Campag and your passing happy to have a go
Thanks but it's for a shitty bike and I'll give Lukes idea a try.
Nice looking tool though. I might have to acquire one for the collection at some point when finances aren't too stretched.
Tim
Posted : 08/06/2011 2:58 pm
Timbur
Don't see why it wouldn't work with the Campy BB??? (Although obviously, you will have to loosen the bolt when/if it starts to move)
It's not just an idea BTW. That's what I've done previously to remove stuck BBs. If you take it to a (good) LBS, they will do exactly the same.
Good luck
PS - Some bike shops hate jobs like this - others seem to have a bit of a thing about them. LBS wouldn't accept payment for trying to removing one of mine despite breaking 2 vices over a fortnight. I paid them with a crate of beer in the end 🙂
Posted : 08/06/2011 3:03 pm
Fluff - I don't doubt it but at present I don't have the correct tool for the BB so am looking for a bodge to save spending £10 on a tool that I'm unlikely to use again. It it used a standard splinned BB removal tool then it would already be removed and in the bin :O)
Posted : 08/06/2011 3:14 pm
You're turning it the right way, I assume?
Posted : 08/06/2011 6:24 pm
Thank you epicyclo. I'm not THAT stupid :O)
Just ordered the tool off eBay. I hope to have to use it again in the future but it'll probably just hang on the tool wall gathering dust.
Posted : 08/06/2011 10:12 pm
timbur - Member
Thank you epicyclo. I'm not THAT stupid :O)...
I have been 🙂
(Bike upside down, brain in neutral)
Posted : 08/06/2011 11:56 pm
Strap wrench?
Posted : 09/06/2011 12:11 am
The correct tool for the job and it's a joy to do.
Lesson learnt.
Luke - I tried your method but there wasn't enough depth to get purchase. Shame, nice idea!
Posted : 18/06/2011 11:09 am
Was it a FAG BB? I saw one of their tools on ebay recently and wondered if you won it?
FAG BB's were the first cartridge BB's that I used after wearing out my first MTB's loose ball cup and cone BB. They were about £15/unit in 1990 and our LBS owner would let us borrow the tool and do the job on the pavement outside the shop!
Posted : 18/06/2011 11:52 am
The right tool for the job is always the best thing. Just did some hope hub bearings with the proper tools - I want to do more now!
Hope you didn't lose too much time on my bodge.
Posted : 18/06/2011 11:59 am
Nope, got the Park one as it goes with the rest of the tool wall :O) (tart? Me? Yes!)
Ooo, and it was a LOT cheaper.
Posted : 18/06/2011 12:30 pm
