i had been removing the main pivot bearing on a five but the bearings
inside were trashed.As i was knocking them out the bearing split and has
left the inner sleeve of the bearing on the mount.Any ideas how i can remove this i am stuck.
Posted : 06/11/2009 8:06 am
get a cylindrical 'something' as close a fit as you can, poor a load of boiling water over it ( the swing arm ), then get your 'something' into what's left of the bearing, angle it over so it'll bind a bit in teh cartridge shell, and wiggle it.
good luck.
Posted : 06/11/2009 8:53 am
It'll be difficult to get behind it in order to give it a good 'whack' so you'll really need to employ something like a sliding hammer - either bought or DIY
Try soaking in it Plus Gas for a while first
Posted : 06/11/2009 9:07 am
