Help please - thru ...
[Closed] Help please - thru axle issues
4 Users
Folks,
The lever of my rear thru-axle (Orange P7 Pro 2017)isn't engaging the axle so when I try to undo it, it's simply unscrewing the lever rather than undoing the axle. The axle itself is not seized and is well greased. Any suggestions as to how I get the axle out so that I can replace it?
Thank you.
Posted : 01/01/2018 5:26 am
File a couple of notches into the other side of the axle and use a chainring tool or similar to undo it?
Posted : 01/01/2018 7:45 am
What type of axle is it?
Posted : 01/01/2018 9:22 am
We had one doing the same recently, I think they ran a tap into the other end, then ran a bolt in so when it tightened, it unscrewed the axle.
Posted : 01/01/2018 1:06 pm
