HELP PLEASE: Rotor ...
[Closed] HELP PLEASE: Rotor size confusion...
 barn
Am in shed. Got a Clark SX front brake - 185 rotor.
Trying to stick it straight on to Post Mount of RockShox SID Race.
There's not enough 'clearance' for the rotor - it fouls on inside of caliper.
Have tried putting a 160 rotor on there and it still fouls...
Am desperate!
Ideally I'd like to run it with the supplied 185, but could use the 160 - question is do I need some sort of adaptor - if so can someone point me to the right one?
Or am I being a dunce and there's a simpler answer...?
Please help - I've got to finish this bike urgently.
Thanks.
Posted : 08/01/2011 8:00 pm
 bol
You'll need an adaptor that is designed for your calliper (make/model) and the size of rotor you have, or do a lot of trial and error bodging with washers/spacers (probably).
Posted : 08/01/2011 8:08 pm
 barn
thanks 'bol'
I found said adaptor in bottom of tool bag and job done - was having a dim moment and you got me through!
cheers - appreciate it.
Posted : 08/01/2011 10:46 pm
