Help please Identif...
[Closed] Help please Identifying Marzocchi forks
I haven't got a pic yet but these are the specs -
2006 forks
20mm bolt through with one pinch bolt each side
black crown, stanchions and steerer
140mm travel
32mm stanchions
540ish mm axle-crown
the only knob is for rebound adjustment
schraeder (preload?) valves on the top of each leg
Any ideas please?
Posted : 05/02/2011 2:28 pm
Have a look [url= http://www.marzocchi.com/template/listProdotti.asp?LN=UK&idC=1561&IdFolder=113&idMY=28182 ]here[/url]?
EDIT: Possibly the Z1 SL's ?
Posted : 05/02/2011 2:47 pm
Thanks for that, looks like it's a Z1 but none of the specs match up exactly, I could have measured the travel slightly wrong and I guess it could be a cut down OEM fork. It's the oil levels I'm trying to find out but should be able to work that out now.
Posted : 05/02/2011 3:15 pm
I think it must be a Z1 sport with no compression adjust...
Posted : 05/02/2011 3:24 pm
