Hi
Just fitted all new seals to my Fox RP2 rear shock. Last piece to go in is the dust wiper seal. I cannot get this to fit in, and have no idea why. Has anyone else had this problem?
I no I sould be able to fit this in about 10 seconds, but I have been trying for ages. The seal is exactly the same as the old one, so come on what am I doing wrong? Unbelieveably frustrating- Help please.
Thanks
Ray
Same happened to mine, the gland the seal sits on had deformed, probably due to neg pressure in past. needed new aircan to repair it so bought coil instead.
Think its a warrenty repair though if still within warranty.
To check have a look in aircan at metal ring-gland that seal sits on, is it distorted?
Thanks seanodav
Unsure what you mean by metal ring gland? The dust wiper seal just fits in the groove between the top of shock the nylon ring inside. It should fit in easy, but I really cant understand why it wont fit. I have only carried out the job, as it was way overdue (according to Fox) for a service. All the other seals went in no problem.
If anyone else as heard of this problem before, please let me know. I cant use my bike till I get it sorted
Thanks again
Ray
Look into aircan, there is i small metal ridge runs all the way around the neck, is it flat or is there a slight bend in it?
Exactly the same story as mine btw
All looks OK to me, no distortion etc.
Cant see how I can go wrong with this, its not that its anything technical or tricky. So its either me in idiot mode, or there is a manufacture problem, which I very much doubt, as the new seals match the old ones as far as I can see.
Why did I ever go to full sus from hardtail...........
The seal does actually just go in easy if the gland is straight.
You do have the plastic bits in behind the gland?
As per picture 21 in this pdf
Thanks again for your help.
Yes, both plastic bits in.
Please click on video link below, I am at 7.08 The guty fits the dust wiper seal in about 5 seds.
Ray
Can't you lube it up and push it in?
Yeah it really is that easy. are you able to get the seal in but its not sitting flat?
Not sure if i've understood you correctly, but it sounds like you're trying to fit the plastic ring and the dust seal into the same groove.The two plastic rings go one either side of the inner seal, the dust seal goes into it's own groove.
Oooppppsss!!!
What an idiot. On closer inspection I was doing what coatesy says. All sorted now.
Thanks a lot guys for your help. Greatly appreciated.
Oh the shame!!
Ray
That's good I can go back now and watch channel 4 ๐
Thats a relief! no spare parts now have we? ๐
