Help needed on sing...
[Closed] Help needed on single ring conversion!!
I've just purchased a dale f29 carbon and would like to convert the sram s1000 double chainset, would it be possible to fit a rotor Q factor 34 tooth single ring to this??? If so which ring do I replace etc etc??
Would appreciate some advice on this, cheers guys
Gary
Posted : 20/06/2013 8:26 pm
Assuming the Rotor ring is 104bcd and the S1000 outer is 120bcd, then no - sorry.
If you can get a BB30 triple* the Rotor ring should go on the middle, assuming chainstay clearance is OK - I'm trying to wheedle out of Cannondale what the max single ring size is for a F1 26er but the information hasn't exactly been forthcoming. I know eg. Niner publish a maximum single ring size.
[i]Edit - CRC have a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=76140 ]SRAM[/url] and [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=54763 ]FSA[/url] triples that might suit[/i]
Posted : 20/06/2013 8:54 pm
