Help me with tyres ...
[Closed] Help me with tyres - maxxis Vs Conti
[#1776730]
To be run tubeless on stans rims. Predominantly peak district riding.
Want a grippy front and fast rolling rear as do most riders!!
thinking maxxis ardent/aspen combo or conti speed king/race king
any thoughts or opinions? Need a sturdy rear sidewall 😉
Posted : 07/07/2010 10:33 am
or advantage/larsen?
Posted : 07/07/2010 10:36 am
I don't like Speed Kings but Race Kings are meant to be very good if you get the expensive compound ones. Search on the weight weenies subforum on MTBR and there's a long thread on them.
I'm thinking of running my DHF on the front and a Race King 2.2 on the rear.
Posted : 07/07/2010 10:38 am
can't mix brands!!!
Posted : 07/07/2010 10:42 am
why?
Posted : 07/07/2010 10:43 am
I like my High Roller front and Race King rear combo. Will u die as I am mixing brands?!?!
Posted : 07/07/2010 10:46 am
Hahah mixed brands upsets the bike tart-facist brigade.
Posted : 07/07/2010 11:32 am
Ardent rear, HR front.
mixed brands look shit - no need as most companies do similar treads anyhow 🙂
Posted : 07/07/2010 12:17 pm
Advantage myself - Not too draggy - excellent sealing on side walls running tubeless and seat very well on my ZTR 355 rims.
Posted : 07/07/2010 12:19 pm
 mttm
Advantage / Aspen combo is good, as is Advantge / Crossmark. For tougher sidewalls than standard, try the "Exo" reinforced versions that Maxxis has started to put out. I know these are currently available in the Ardent, not sure about the others, yet.
Posted : 07/07/2010 12:22 pm
I run advbantage ust both ends on Flow rims around the Peaks on my hardtail. The Advantage really does work better with lower pressure though. I found them pretty pants at 40 psi but excellent at 22.5/27.5 f/r
Posted : 07/07/2010 12:27 pm
Personally if it was a choice between the two brands I'd go for the Maxxis side of things.
Of how about Schwalbe Nobby Nic / Racing Ralph like your name sake 😆
Posted : 07/07/2010 12:30 pm
Also look at Rubber Queens if you're considering High Rollers. Race King / Rubber Queen's a good combo if you want a fast rolling tyre on the back but it's more hardpack-specific than the Maxxis semi-tread tyres ime. very fast in the right conditons tho.
Posted : 07/07/2010 1:01 pm
