Help Me STW … hub e...
Help Me STW … hub end caps … mystery hub
Help Me STW … you’re my only hope.
My Google Fu is failing me at the moment.
I have a hub that I’m looking to convert from 12mm to QR. The hub is branded solely as a Bombtrack hub. Bombtrack have suggested it’s an Origin 8 hub but I cannot see anything in their lineup that looks similar 😕
The NDS end cap is a push on with a o ring ala Hope. This reveals an axle with a slot cut into it that helps you remove the threaded DS end cap. Simples ☺️
Can I find QR end caps in this arrangement … can I heck!
I faintly recall seeing some Spank hubs like this but that draws a blank too.
Can anyone help?
Many thanks in advance.
Mark
Posted : 11/05/2024 6:52 pm
Sounds like an older Chosen hub , often rebranded by Stans as ZTR , Wiggle ? and many others
but no clue as to spares sorry
Posted : 11/05/2024 8:04 pm
Forget about changing the end caps. Just fit one of the generic 12mm->qr conversion axles. They are about £10 them you can get on with you life.
Posted : 12/05/2024 12:10 am
@nixie - unfortunately this is a rear hub.
Posted : 12/05/2024 9:38 am
Would this do the job?
Posted : 12/05/2024 10:17 am
Gah that's annoying. How about trimming the end caps by 3mm so the hub becomes 135x12mm then using something like this (pretty sure there will be cheaper versions available).
https://reverse-components.com/en/products/135mm-%C3%B812-10mm-rear
Posted : 12/05/2024 11:50 am
