Help me solve what ...
[Closed] Help me solve what should be the easiest mechanical job on a bike...
Namely screwing in the rear mech to the hanger. I've bolted in many rear mechs in my time, but just bought a new dolan, and the threaded hole on the hanger to screw in the mech is too big. Never had this issue before. I thought all rear mech bolts were the same size. Do I need some kind of sleeve to make it work?
Threads haven't been stripped, both hanger and mech are brand new.the hole is just far too big.
Posted : 03/09/2019 1:24 pm
narrow it down a bit?
Frame, mech etc.
Posted : 03/09/2019 1:28 pm
Is it missing some sort of Direct Mount adapter? I
Posted : 03/09/2019 1:36 pm
I was expecting one of those aligning stem with front tyre using lasers threads.
Are you sure the hole isn't for bolting on a derailler hanger, which is missing? Of is it designed to have some sort of breakable insert that is missing? It sounds to me like something's missing.
Posted : 03/09/2019 1:37 pm
Yeah, like my RM has
Not seen road bikes with them myself
Posted : 03/09/2019 1:53 pm
Yep. Newer road mechs have them too.
Posted : 03/09/2019 2:03 pm
Is this a stealth rant against new standards?
Posted : 03/09/2019 2:06 pm
Pic via link. It's definitely a mech hanger. I don't think I'm missing anything. I thinking just the wrong size.
Posted : 03/09/2019 2:08 pm
Posted : 03/09/2019 2:09 pm
The thread on a normal QR rear axle is the same as that on a rear mech. Might be an easy way to check, if you have a wheel/hub hanging around. That photo does make the hole look too big, in which case I'd be asking Dolan whether there is a bit missing.
Posted : 03/09/2019 2:11 pm
Just asked them. The hanger is faulty apparently
Posted : 03/09/2019 3:00 pm
Crikey! How to confuse the punters ๐Ÿ˜†
Posted : 03/09/2019 3:17 pm
You appear to be missing the helicoil or threaded insert
https://www.dolan-bikes.com/parts-accessories/frame-components/dropouts/scala-drop-out.html
Posted : 03/09/2019 3:22 pm
Bit of a weird looking thing anyway.
To be fair,it is on the bottom shelf and out of focus.
Posted : 03/09/2019 3:29 pm
Would the focus affect the fit, though? Maybe it would feel a bit more vague and fuzzy as you wound the bolt it?
I'll try wearing my wife's glasses next time I'm doing this, in the name of Science.
Posted : 03/09/2019 3:57 pm
never mind, fasthaggis - I enjoyed it ! ๐Ÿ™‚
Posted : 03/09/2019 9:38 pm
