help me convert a 1...
[Closed] help me convert a 12mm rear hub to fit my Dialled Alpine rear drops.....
i've sort of inadvertantly bought a 12mm Sun Ringle Jumping Flea rear hub for a lot less that the rrp. guy thought it was 10mm, i didn't think/care to check....
DT Swiss have a converter, but that is specifically for their own hubs.
i've found [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40569 ]THESE[/url] from mavic, but don't know if they'll work for my hub. it says on CRC they are specifically for Mavic.... can't be much difference, can there?
any pointers gratefully recieved.
cheers...
j
Posted : 26/03/2011 5:44 pm
You need a 12mm to QR converter axle thing to let you slot the axle thing into the 12mm hole and then put a QR through the axle converter thing.
http://www.chainreactioncycles.com/Models.aspx?ModelID=34779
Posted : 26/03/2011 6:19 pm
cheers rickos... but i've a 10mm axle for the hub, except the hub is 12mm.
need a system that'll work with sun ringle. can't imagine that the mavic system wouldn't work....
Posted : 26/03/2011 6:27 pm
