I've got a bit of disc rub and the rotor isn't centralised. I'm guessing you have to use longer fixing bolts and some shims/thin washers.
Is this right, if it's not how do you do it?
It's not easy as set up post mounts. ๐
Thanks in advance
Posted : 17/11/2012 2:33 pm
Correct. Long enough bolts + shims. If lbs doesnt have them in stock Halfords often do.
if the IS mount isn't faced its worth doing if its difficult to align as m4's have a long pad contact area so exaggerates any misalignment.
Posted : 17/11/2012 2:49 pm
yes, use shims. Most 'washers' will probably be too thick and move it too far the other way.
No need to use longer bolts though, we're only talking fractions of a mm.
Posted : 17/11/2012 2:50 pm
