HELP. Manitou Nixon...
[Closed] HELP. Manitou Nixon Elite 115-145mm TPC. Easy to service ??????????
Hi,
Trying to sort a really crappy feeling set of the above,to start with i was going to whip the lowers off, for a clean and oil change. Has anyone done this before ? anything i should know before attempting it ?
any thoughts will be greatly appreciated.
Thanks in advance
Leigh
Posted : 07/07/2010 6:46 pm
I think a service manual can be found on the Enduroforkseals website, they have them for most other Manitou forks. TPC should probably be easier than the Snap/Absolute systems.
Posted : 07/07/2010 6:55 pm
Dead easy. Basically the same as current RS forks. The damper rod under the rebound adjuster is a REVERSE thread.
Posted : 07/07/2010 8:23 pm
