Ahead of a trip to cyb this weekend I took the opportunity to degrease my drivechain and dismantled my mech in the process. Failure to pay proper attention to all the parts has resulted in me losing one of the two tiny bolts that hold it together
Any help on how I can quickly get hold of a replacement?
LBS will rescue you.
If they're the same as SLX ones then there's a chap that will cannibalise the one from his rear mech just round the corner from you 😉
Is this the one? https://www.sjscycles.co.uk/gear-spares/shimano-xtr-rdm972-guide-pulley-bolt-m5-x-126mm-y5wj21000/
or if you still have that one, this one? https://www.sjscycles.co.uk/gear-spares/shimano-xtr-rdm972-tension-pulley-bolt-m5-x-1435mm-y5vw24000/
submarined
Member
If they’re the same as SLX ones then there’s a chap that will cannibalise the one from his rear mech just round the corner from you 😉
Simon?
andyl
or if you still have that one, this one? https://www.sjscycles.co.uk/gear-spares/shimano-xtr-rdm972-tension-pulley-bolt-m5-x-1435mm-y5vw24000//blockquote >
It's one of them, I didn't appreciate the two were different. The pic I posted is the one I have left so I obviously need the other one. Thanks for the links.
Simon?
Hullo 😀
See you tonight
